Home > Maintenance & Modifications > Engine oil - suck or drain?
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
Just wondering whos does what, I have always drained but I am told that sucking is gaining over draining and some manufacturers may delete the drain plug.. Shocked
If you do 'suck' which suction thingy do you use? BM52
Post #262959 1st Sep 2013 7:55pm
StephenO
I've been wondering about this too, at the moment I drain it after an engine flush but hesitant if I was to suck I might miss some? Anyway I was looking at this -
http://www.ebay.co.uk/itm/370857766088?ssP...1438.l2649 2007 Defender Puma Tonga Green
2015 Range Rover Sport Autobiography Corrie Grey
1968 Series 2a Bronze Green
1995 Defender 90 Coniston Green
2005 Discovery 3 Zambezi Silver
Post #262966 1st Sep 2013 8:07pm
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
Main dealers suck (pun intended) for ease as the old oil goes straight out to a bulk container ready for collection,no mess in the workshop no handling "hazardous" waste and no time spent removing undertrays etc.I prefer to drain as the flow of nice warm oil drags all the crud out of the sump. 2005 Td5 90 XS
Steve
Post #262967 1st Sep 2013 8:08pm
Sockpuppet
I prefer drain. The sump plug on by tdci focus needs replacing every few years so it's always a good idea to check the seal when you remove it.
Post #262969 1st Sep 2013 8:12pm
Sonarmender
England 2015 Defender 90 Puma 2.2 HT Corris Grey
Not all main dealers suck, my local main dealer will only drain. You only have one life, live it....forget the cost.
90XS Hardtop
Post #262998 1st Sep 2013 9:52pm
jimbob7
Mi mates peugeot 2ohsummut dunt have a drain plug. I've not decided if thats the best way to go.
Post #263007 1st Sep 2013 10:35pm
mick
Drain tried a suction thing on my outboards load of crap
Post #263008 1st Sep 2013 10:42pm
cornish rattler
United Kingdom 1988 Defender 90 200 Tdi CSW Bronze Green
The only thing I have against these suction pumps is that if you remove the pipe out of the dipstick tube whilst the pump is still sucking it looses its suction and oil goes all over your engine but its just a matter of making sure the pump has stopped sucking before you remove the pipe Smile Graham
1988 Defender 90 county 200tdi ( Beast )
Paul Walker 1973-2013
( I Almost Had You )
Post #263026 2nd Sep 2013 12:01am
excossack
I prefer the method of get the engine nice and warm and then drop the oil with the drain plug. Having a difflock drain plug helps. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #263051 2nd Sep 2013 8:57am
K9F
Thumbs Up Thumbs Up
http://www.drainplug.co.uk/accessories.html If you go through life with your head in the sand....all people will see is an ar5e!!
Post #263052 2nd Sep 2013 9:09am
XS Pete
England 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
I've got a German badged one identical to that and found it pretty good. I've even used it to fill the gearbox with a measured amount of fresh oil, as there is no level plug, and the filler is tricky to get to with a one litre 'squeeze bottle'. I've also used it on lawn mowers and other motors and had no problems so far.
Pete
Post #263093 2nd Sep 2013 12:47pm
bm52
So - it is looking like Defender owners are not a bunch of suckers then Confused
I do like the look of the Femco drain plug, noted for when I next change the oil as from then on I take over the servicing as it will be nearly 4 years old. I change the oil in July before the French trip and I'd like to say I didn't spill one drop Whistle BM52
Post #263116 2nd Sep 2013 2:08pm
WarPig
Spit or swallow Neutral
Wouldn't sucking cause any bits of metal to be sucked up through the engine?
Post #263118 2nd Sep 2013 2:30pm
I'm guessing all the various main dealers I've used have drained - as I've always had a new sump washer on the bill but then I've nearly always been charged for screenwash when I always brim it before taking it in Laughing
Post #263327 3rd Sep 2013 8:35am
Sucking usually involves a long tube being inserted through the dip stick tube down into the sump, so that shouldn't be a problem. Darren
Post #263336 3rd Sep 2013 9:27am
