![]() | Home > Maintenance & Modifications > Engine oil - suck or drain? |
StephenO Member Since: 03 Dec 2010 Location: Glasgow Posts: 246 ![]() ![]() |
I've been wondering about this too, at the moment I drain it after an engine flush but hesitant if I was to suck I might miss some? Anyway I was looking at this -
http://www.ebay.co.uk/itm/370857766088?ssP...1438.l2649 2007 Defender Puma Tonga Green 2015 Range Rover Sport Autobiography Corrie Grey 1968 Series 2a Bronze Green 1995 Defender 90 Coniston Green 2005 Discovery 3 Zambezi Silver |
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 ![]() ![]() ![]() |
Main dealers suck (pun intended) for ease as the old oil goes straight out to a bulk container ready for collection,no mess in the workshop no handling "hazardous" waste and no time spent removing undertrays etc.I prefer to drain as the flow of nice warm oil drags all the crud out of the sump. 2005 Td5 90 XS
Steve |
Sockpuppet Member Since: 17 Sep 2011 Location: Leicester Posts: 479 ![]() ![]() |
I prefer drain. The sump plug on by tdci focus needs replacing every few years so it's always a good idea to check the seal when you remove it.
Sonarmender Member Since: 04 Apr 2013 Location: Guz Posts: 338 ![]() ![]() ![]() |
Not all main dealers suck, my local main dealer will only drain. You only have one life, live it....forget the cost. 90XS Hardtop |
Mi mates peugeot 2ohsummut dunt have a drain plug. I've not decided if thats the best way to go.
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 ![]() ![]() ![]() |
Drain tried a suction thing on my outboards load of crap
cornish rattler Member Since: 31 Aug 2013 Location: Manchester Posts: 642 ![]() ![]() ![]() |
The only thing I have against these suction pumps is that if you remove the pipe out of the dipstick tube whilst the pump is still sucking it looses its suction and oil goes all over your engine but its just a matter of making sure the pump has stopped sucking before you remove the pipe
![]() 1988 Defender 90 county 200tdi ( Beast ) Paul Walker 1973-2013 ( I Almost Had You ) |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6030 ![]() ![]() ![]() |
I prefer the method of get the engine nice and warm and then drop the oil with the drain plug. Having a difflock drain plug helps. 1999 Defender TD5 110
![]() ![]() http://www.drainplug.co.uk/accessories.html If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
XS Pete Member Since: 13 Jan 2011 Location: Suffolk Posts: 632 ![]() ![]() ![]() |
I've got a German badged one identical to that and found it pretty good. I've even used it to fill the gearbox with a measured amount of fresh oil, as there is no level plug, and the filler is tricky to get to with a one litre 'squeeze bottle'. I've also used it on lawn mowers and other motors and had no problems so far. Pete |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 ![]() ![]() ![]() |
So - it is looking like Defender owners are not a bunch of suckers then
![]() I do like the look of the Femco drain plug, noted for when I next change the oil as from then on I take over the servicing as it will be nearly 4 years old. I change the oil in July before the French trip and I'd like to say I didn't spill one drop ![]() |
WarPig Member Since: 05 Dec 2009 Location: Sheffield Posts: 1748 ![]() ![]() ![]() |
Spit or swallow
![]() Wouldn't sucking cause any bits of metal to be sucked up through the engine? |
I'm guessing all the various main dealers I've used have drained - as I've always had a new sump washer on the bill but then I've nearly always been charged for screenwash when I always brim it before taking it in ![]() |
Sucking usually involves a long tube being inserted through the dip stick tube down into the sump, so that shouldn't be a problem. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
