Home > Td5 > Help! Engine cuts out at full throttle
Page 6 of 10 <12345678910>
HansT
Sweden 2004 Defender 110 Td5 SW Belize Green
landy andy wrote:
It being dirty so getting a Censored signal from flywheel. Easy to take out and clean.
Andy
As a matter of fact I looked for it today. Is it sitting at the back of the engine, right side, rather high up? I will do some cleaning during the weekend Confused
Hans
Post #262267 29th Aug 2013 9:36pm
landy andy
Yes that's it. Passenger side for you, high up on bell housing by the corner of the cylinder head area, one bolt holds it in, and has wire going to it.
Andy
Post #262277 29th Aug 2013 9:50pm
HansT
Lou Sparts wrote:
When you take your foot off the gas the ECU will stop fuel being injected (this is all to do with emissions) until the revs approach tickover and will then will start to inject fuel to prevent a stall.At least thats my understanding of it.
Thanks Andy and Lou for the info. One thing less to worry about.
Hans
Post #262286 29th Aug 2013 10:16pm
HansT
Andy
Took out the crank sensor today. Not so easy to get at.
It was very dirty and the end looked to be damaged. Also the O-ring was missing. I cleaned it up and put it back (without O-ring). And I was convinced that this would solve the problem.
Tried the engine again and the problem was still the same. Identical as before. So I guess the crank sensor was not the reason.
Do you think that I should order a new sensor or is it enough with a new O-ring?
Sent before and after pictures to Andy as I can not upload.
Hans
Post #262639 31st Aug 2013 4:39pm
Macpaul
United Kingdom 2013 Defender 110 Puma 2.2 USW Loire Blue
I gather that the crank sensor is the only part that really must work. The ECU can fill in values for everything else if it has to.
It is also very position-sensitive. LR sell shims to overcome the problem a batch of TD5s had where the sensor was fractionally too far in causing mis-timing problems.
That said, it is working, at least up to 2,500rpm. I'd get a new o-ring to stop more dirt coming in and maybe seat it more accurately, but it's hard to see how this is the root of the problem. Unless the end really is damaged...... 2003 Td5 110 Hardtop
Now a 2013 110 USW too.
Post #262644 31st Aug 2013 4:54pm
Splitpin
Try unplugging the 2 solenoids on the inner wing near the throttle valve.
Post #262655 31st Aug 2013 5:32pm
bob neville
Might also be worth getting the shim for the crank sensor as well.
After 11 years my TD5 started missing/losing power between 2500 and 2600 rpm for some reason.
The indie working on it fitted the shim and the missing stopped and it now drives very smoothly.
Agree it probably is not the root cause but would be well worth doing to see what difference it makes.
Any chance of a picture of the end of the sensor to see the extent of the damage ?
2013 Defender 90 CSW - sold
Post #262669 31st Aug 2013 6:20pm
HansT
I will try that tomorrow. What do these solenoids do? What will happen when I disconnect them? Please bear in mind that I just had this vehicle for a couple of months and are quite unfamiliar with it.
Hans
Post #262685 31st Aug 2013 7:07pm
HansT
Bob
Do you happen to know the part No of the shim and the O-ring?
I can not upload any pictures so I have mailed to Andy. I can mail to you as well if you send me your email.
Hans
Post #262691 31st Aug 2013 7:23pm
Macpaul
No part number but this is a pic. of the shim.
Post #262696 31st Aug 2013 7:40pm
landy andy
I would change this for a new one, main dealer only, and order a spacer to go with it. My thinking about the cps was that as the engine spun faster that it may cause a confused signal, so engine cuts out. I would think many other faults would put engine into limp mode or tick over, but I know cps is one of the few items that will stop a Td5.
Andy
Post #262699 31st Aug 2013 8:00pm
bob neville
I agree Andy, that does not look healthy. Looks like one side has been ground down.
A new sensor and spacer would be a good place to start.
Post #262737 31st Aug 2013 8:52pm
landy andy
It must be hitting on the flywheel to do that damage.
Andy
Post #262744 31st Aug 2013 9:03pm
Macpaul
That is not right.
Sounds like yours may be one of the ones in the batch I mentioned.
Def get a new one and shim. 2003 Td5 110 Hardtop
Post #262747 31st Aug 2013 9:09pm
HansT
Can anyone help me with part Nos for crank sensor and shim please?
Hans
Post #262754 31st Aug 2013 9:48pm
