Home > Maintenance & Modifications > Use of Puma empty dash space
Cheshire110
Has anyone found a neat use for the empty 'screen' under the fuel/temp gauge in the puma dash?
It's prime real estate and obviously comes from where the multiple-display on the F2 etc. is.
Don't know what could go there, thermometer? Didn't know if anyone had any bright ideas or has seen anything Cheers, David
Post #262039 28th Aug 2013 11:05pm
BigWheels
Nothing there = something less to go wrong Whistle
But a low box selected warning light would be cool, to go with the difflock warning light. Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Post #262052 28th Aug 2013 11:48pm
Unless you are an electrical wizard, probably best to leave alone, the dash binnacle is sync'd with the 10AS unit and the ECU
Post #262063 29th Aug 2013 6:25am
yaho
Poland 2007 Defender 90 Puma 2.4 SW Keswick Green
I have put there the ScanGauge:
It covers partly lights-on indicator. If I would able to find alternative device just neatly covering unused space I would put it instead. Janusz
www.yahodeville.com
Post #262069 29th Aug 2013 7:02am
william8
Scotland 2008 Defender 90 Puma 2.4 XS CSW Zambezi Silver
You know i have never noticed that Rolling with laughter William
Post #262127 29th Aug 2013 11:50am
You can put something over the face but not in from behind as there is a PCB in the way
Post #262130 29th Aug 2013 12:01pm
Regard
South Africa 2011 Defender 110 Puma 2.4 X-Tech LE Orkney Grey
'Tis is my use of that space:
Post #262135 29th Aug 2013 12:31pm
d j hutton
England 2011 Defender 110 Puma 2.4 USW Orkney Grey
That looks neat, how is mounted if you don't me asking. I'd like to get mine there as its stuck on the window at the moment.
DJ 1989 200tdi 90 csw
2011 110 usw Orkney grey
Buy British 🇬🇧
Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html
Post #262203 29th Aug 2013 5:11pm
Regard
DJ
No problem.
Mounted with adhesive Velcro. This side view will explain:
Post #262211 29th Aug 2013 6:30pm
Hifonics
2013 Defender 110 Puma 2.2 USW Corris Grey
What is that display?
Post #262251 29th Aug 2013 9:09pm
Regard
Post #262257 29th Aug 2013 9:22pm
^^ I like that. even with international postage to the UK of $25 the price is very good! How does it compare with a scangauge? ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #262261 29th Aug 2013 9:27pm
Cheshire110
Regard wrote:
That is the UtraGauge
http://www.ultra-gauge.com/ultragauge/
Just been looking on website, WOW. Is it as good as it looks?!
What info can you get with the defender?
Sorry if you have a thread / info somewhere else, you can link if easier! Cheers, David
Post #262262 29th Aug 2013 9:29pm
Regard
Not bad. Can also read and clear fault codes and gives you most important info.
IIRC, Lorryman wrote a review and comparrison somewhere here about the Ultragauge VS some of the more well know code readers.
Will see if I can find it....
Post #262264 29th Aug 2013 9:32pm
Cheshire110
Yeah it looks really good!
Mpg, ave mph, fault codes etc, temps, and less than 50 Cheers, David
Post #262266 29th Aug 2013 9:35pm
