Home > Maintenance & Modifications > Use of Puma empty dash space
Page 2 of 2 <12
Regard
South Africa 2011 Defender 110 Puma 2.4 X-Tech LE Orkney Grey
Post #262269 29th Aug 2013 8:37pm
Regard
IIRC it can read some thing ridiculous like 48 parameters in the Puma.
These include:
Battery voltage
Coolant temp
Turbo boost
Manifold pressure
Fuel rail pressure
EGR%
Engine load
MAF%
Throttle position
Manifold intake Temp
Bhp/Kw
Nm
True road speed (same as GPS speed!)
RPM
Etc, etc, etc........
And then masses of fuel consumption figures (which is a bit of a PITA to set up correctly)
On top of this it reads fault codes and is able to clear and reset them as well as the MIL light.
Post #262270 29th Aug 2013 8:44pm
That is going to go on the the wanted list now. Whistle I must have missed the thread. Confused On fault codes along a code reader on E-bay is £30 and this does more than that. I guess being picky but a pity the display doesn't match the dash though. Sad ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°*\\_
Post #262272 29th Aug 2013 8:44pm
Cheshire110
Added to wish list! Thanks for all the info, your setup looks good! Cheers, David
Post #262280 29th Aug 2013 8:55pm
camelman
other option is too buy a Bluetooth obdc plug in from ebay for £10 and buy the 'Torque' App (android) for £3 and you get fully customisable displays on any android phone / tablet.
Post #262284 29th Aug 2013 9:06pm
spudfan
Ireland
Excuse my inorance, but where does it plug into? Under the dash or under the seat? 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #262298 29th Aug 2013 9:45pm
Regard
In to the OBDII port under the steering.
Post #262324 30th Aug 2013 4:49am
They also come with a screen mount. I used mine in the arctic to monitor the air intake box temperature, when it dropped below -10c I switched the breather heater in, but there are loads of settings monitored and it can configure upto 7 pages of information, alerts and fuel consumption. It's not magic, it just knows how to talk to the engine management
Post #262328 30th Aug 2013 6:15am
Page 2 of 2 <12
