![]() | Home > Maintenance & Modifications > Use of Puma empty dash space |
Cheshire110 Member Since: 26 Jul 2013 Location: London Posts: 2788 ![]() ![]() |
Has anyone found a neat use for the empty 'screen' under the fuel/temp gauge in the puma dash?
It's prime real estate and obviously comes from where the multiple-display on the F2 etc. is. Don't know what could go there, thermometer? Didn't know if anyone had any bright ideas or has seen anything Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
Unless you are an electrical wizard, probably best to leave alone, the dash binnacle is sync'd with the 10AS unit and the ECU
yaho Member Since: 26 Nov 2008 Location: Bialystok Posts: 200 ![]() ![]() ![]() |
I have put there the ScanGauge:
![]() It covers partly lights-on indicator. If I would able to find alternative device just neatly covering unused space I would put it instead. Janusz www.yahodeville.com |
william8 Member Since: 03 Apr 2013 Location: Motherwell Posts: 259 ![]() ![]() ![]() |
You know i have never noticed that
You can put something over the face but not in from behind as there is a PCB in the way
Regard Member Since: 08 Dec 2011 Location: RSA Posts: 251 ![]() ![]() ![]() |
'Tis is my use of that space:
![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
d j hutton Member Since: 30 Jul 2009 Location: Dorset Posts: 1044 ![]() ![]() ![]() |
That looks neat, how is mounted if you don't me asking. I'd like to get mine there as its stuck on the window at the moment.
DJ 1989 200tdi 90 csw 2011 110 usw Orkney grey Buy British 🇬🇧 Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html |
No problem. Mounted with adhesive Velcro. This side view will explain: ![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Hifonics Member Since: 11 May 2010 Location: Bridgwater Posts: 63 ![]() ![]() |
What is that display?
That is the UtraGauge
http://www.ultra-gauge.com/ultragauge/ |
^^ I like that. even with international postage to the UK of $25 the price is very good! How does it compare with a scangauge? _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Just been looking on website, WOW. Is it as good as it looks?! What info can you get with the defender? Sorry if you have a thread / info somewhere else, you can link if easier! Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
Not bad. Can also read and clear fault codes and gives you most important info.
IIRC, Lorryman wrote a review and comparrison somewhere here about the Ultragauge VS some of the more well know code readers. Will see if I can find it.... |
Yeah it looks really good!
Mpg, ave mph, fault codes etc, temps, and less than 50 Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
