| Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6678
Time for new glasses Brendan .... |
| ttuck3r Member Since: 03 Feb 2013 Location: Dunning Scotland Posts: 277
Got my Defender back from Strathearn Engineering today all fixed up, after me snapping the bolts off the EGR very happy Thanks to the Lads for getting to it so quickly..
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21044
How'd you manage that? ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
| Les Brock Member Since: 20 Mar 2012 Location: Stroud, Glos Posts: 188
I'm ok I have lockable flush bonnet pins The main reason for me fitting them TBH was to get rid of the silly plastic insert Regards Les |
| WarPig Member Since: 04 Dec 2009 Location: Sheffield Posts: 1748
I'd lime to know this as well. Do they stop the bonnet being tilted back and then lifted straight out? |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18058
Yes, you would need tools to remove the bonnet, so it slows the villains down and makes your neighbour's Defender an easier target. It is also easy enough to make it very hard to remove these hinges - use one (or more) shear nut to secure each hinge to the bonnet, and use a shear nut and socket head cap screw with Loctite to attach the hinge to the bulkhead. Then glue a ball-bearing in the socket of the capscrew. |
| bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189
Drove a beautiful track across valley and hills in the Tarn region near Galliac. BM52
| YeomanOfTheBar Member Since: 04 Nov 2012 Location: North Notts Posts: 210
Got my truck back from Waxoyling at Tim Fry's in Cheltenham
| LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11327
Re-attached my newly powder coated side steps using nice, shiny stainless nuts and bolts to my recently dinitrolled chassis, proving that my OCD is alive and well
I did, however, run out of rivets to re-attach the rubber treads Click image to enlarge Click image to enlarge Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
| PK1 Member Since: 19 Oct 2012 Location: Gloucestershire Posts: 96
Took Landy for its MOT today and it passed with flying colours
Range Rover Sport HSE |
| theorangebandit Member Since: 03 Jun 2013 Location: Stowmarket Posts: 862 |
today i righted a few oddities first off was the traditional land rover wonky steering wheel, which is now slightly less wonky but towrads the O/S now instead. love land rover quirks !
Click image to enlarge Click image to enlarge then i found the tweeter that was pushed into the dash by the 9ft logs mother in law had me collect. at which point i saw the opportunity to claim "see i told you a land rover made sense" to which silence was my reply Click image to enlarge Click image to enlarge then i broke into the dash board to refit the cable that had unclipped itself from the recirculate switch for the fans, the cable had become rather bent which caused it to pop off. so straitened it up with my man hands and sorted ! Click image to enlarge Click image to enlarge a good day however i want to re hang every single door as each of them have there own special quirks, any one got any tips? also on 110 CSW does any one else get splashed in the face when you close the rear passenger doors in and after teh rain ? |
Been cleaning the chassis up all afternoon. Damned hard work but got to be done. In better condition than I though but that's a good thing! Better to underseal early than too late.
Bolted the mud flaps back on today. Again, newly powder coated and using stainless fixings:
Click image to enlarge You can just make out the neoprene isolating pad between the bracket and underside of the rear wing. There's another on the inside too, which together serve to introduce a degree of flexibility. This is to prevent the work hardening of the wing lip that leads to fracturing of the aluminium. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
| Mr Baldylocks Member Since: 15 Jul 2010 Location: Nearer my home than yours. Posts: 487
Now Martin has helped with this here are a few pictures of my pride and joy
I hope you like them. Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Life is one big adventure, that's why we have the vehicle for the journey. |
| All times are GMT |
