Page 547 of 1392 <123 ... 546547548 ... 139013911392>
leeds wrote:
Also looks like you have got a Nakatenga heritage grill as well Razz
Brendan
Time for new glasses Brendan ....
Post #258100 12th Aug 2013 10:36am
BigWheels
leeds wrote:
Yes they are bonnet security hinges.
Slows down the thieving scumbags.
To best of my knowledge there are three types of security hinges.
Those above are from Off Road tec and then there are the Entreq ones. We stock both of those.
Then there are the GMB ones stocked by Kevin at Mud
Brendan
But there is still (on view) access to a fixing bolt. So what deterrent are any such really, on their own?
Perhaps under-bonnet hinges in addition would be better, if such an adaption is possible. Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Post #258479 13th Aug 2013 10:16pm
ttuck3r
Scotland 1999 Defender 90 Td5 HT Caledonian Blue
Got my Defender back from Strathearn Engineering today all fixed up, after me snapping the bolts off the EGR very happy Thanks to the Lads for getting to it so quickly.. Thumbs Up
Post #258483 13th Aug 2013 10:25pm
ttuck3r wrote:
After me snapping the bolts off the EGR.
How'd you manage that? Shocked ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #258577 14th Aug 2013 10:53am
Les Brock
Brendan
I'm ok I have lockable flush bonnet pins Mr. Green
The main reason for me fitting them TBH was to get rid of the silly plastic insert Mad
Regards
Les
Post #258584 14th Aug 2013 11:19am
WarPig
I'd lime to know this as well. Do they stop the bonnet being tilted back and then lifted straight out?
Post #258619 14th Aug 2013 2:00pm
Yes, you would need tools to remove the bonnet, so it slows the villains down and makes your neighbour's Defender an easier target. Shocked
It is also easy enough to make it very hard to remove these hinges - use one (or more) shear nut to secure each hinge to the bonnet, and use a shear nut and socket head cap screw with Loctite to attach the hinge to the bulkhead. Then glue a ball-bearing in the socket of the capscrew.
Post #258631 14th Aug 2013 3:08pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
Drove a beautiful track across valley and hills in the Tarn region near Galliac. BM52
Post #258640 14th Aug 2013 3:50pm
YeomanOfTheBar
United Kingdom 2013 Defender 110 Puma 2.2 DCPU Santorini Black
Got my truck back from Waxoyling at Tim Fry's in Cheltenham Thumbs Up 2013 Defender 110 XS DCPU
Post #258689 14th Aug 2013 9:07pm
Re-attached my newly powder coated side steps using nice, shiny stainless nuts and bolts to my recently dinitrolled chassis, proving that my OCD is alive and well Mr. Green
I did, however, run out of rivets to re-attach the rubber treads Rolling Eyes
 Darren
Post #258693 14th Aug 2013 9:11pm
PK1
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Took Landy for its MOT today and it passed with flying colours Shocked
Thumbs Up Defender 110 TDCi XS SW
Range Rover Sport HSE
Post #258723 14th Aug 2013 10:51pm
theorangebandit
today i righted a few oddities first off was the traditional land rover wonky steering wheel, which is now slightly less wonky but towrads the O/S now instead. love land rover quirks ! Very Happy
then i found the tweeter that was pushed into the dash by the 9ft logs mother in law had me collect. at which point i saw the opportunity to claim "see i told you a land rover made sense" to which silence was my reply
then i broke into the dash board to refit the cable that had unclipped itself from the recirculate switch for the fans, the cable had become rather bent which caused it to pop off. so straitened it up with my man hands and sorted ! Thumbs Up
a good day however i want to re hang every single door as each of them have there own special quirks, any one got any tips?
also on 110 CSW does any one else get splashed in the face when you close the rear passenger doors in and after teh rain ?
Post #258898 15th Aug 2013 5:51pm
Been cleaning the chassis up all afternoon. Damned hard work but got to be done. In better condition than I though but that's a good thing! Better to underseal early than too late.
Smile ____\We|Will|Win/___
Post #258933 15th Aug 2013 7:51pm
Bolted the mud flaps back on today. Again, newly powder coated and using stainless fixings:
You can just make out the neoprene isolating pad between the bracket and underside of the rear wing. There's another on the inside too, which together serve to introduce a degree of flexibility. This is to prevent the work hardening of the wing lip that leads to fracturing of the aluminium. Darren
Post #258943 15th Aug 2013 8:32pm
Mr Baldylocks
United Kingdom 2002 Defender 90 Td5 CSW Bonatti Grey
Now Martin has helped with this here are a few pictures of my pride and joy Thumbs Up
I hope you like them.
 Life is one big adventure, that's why we have the vehicle for the journey.
Post #258946 15th Aug 2013 8:34pm
