Home > In Car Electronics > The definitive Defender ICE thread
Page 41 of 71 <123 ... 404142 ... 697071>
jont wrote:
So I've three spare leads on the Pioneer loom - a light green which says it has to connect to 'parking brake' ? ... a purple/white which wants to connect to 'reverse-gear signal input' and a black/yellow which wants to connect to 'mute' ... any ideas if these are needed or where they might go ?
They'd only be needed if you want to make use of the functions that they relate too. The 'reverse gear signal input' will be for a reversing camera and the 'mute' will clearly be if you are using some sort of fixed hands free system. I'd hazard a guess that the 'parking brake' connection is to do with watching video and only allowing it when you've stopped.
'P.cont' will be a permanent live feed so you can use it with the ignition off and probably enable it to keep radio pre-sets. Darren
Post #258042 11th Aug 2013 9:38pm
jont
2006 Defender 90 Td5 XS CSW Santorini Black
Hifonics wrote:
What speakers are they? Are they a direct replacement or was cutting required?
Hi - they are Kenwood KFC-E1064's ... got them from justkenwood.co.uk
They are a direct fit - although you will need to cut/shape/Dremel the back lip to the speaker card to fit the retaining clips for the new, slimmer screws they supply ... took about 5 mins once I'd carefully done the first one !
I also got some KFC-ST30 tweeters and a KSC-SW01 active subwoofer to fit next Wink
Jon
Post #258044 11th Aug 2013 9:58pm
jont
Thanks Darren - I'd sort of figured what they were - was really asking if there is something specific on the Defender loom to connect them to ? ... am thinking of getting a reversing camera so that would get hooked up - what would the parking brake connect to ?
cheers
Jon
Post #258047 11th Aug 2013 10:02pm
Either the switch on the handbrake or the feed to the brake light on the dash. I think the latter will be more difficult though, as it'll be integrated into the instrument pack. Darren
Post #258052 11th Aug 2013 10:21pm
P.CONT - (normally Blue) is for turning on an Amplifier or as LRA say's Amplifier however it is normally used for. It's pretty much a switch in effect and you simply extend this wire.
REVERSE (can't remember colour but all labelled) Don't connect this unless you are actually fitting a reverse camera. I would then look at it.
PARK SW - (Again can't remember colour) But to make life easier for you and so you can use your video features all the time. Simply earth it anywhere that has a good earth I.E. A chassis bolt or structural fixing so no where on the Alu body. You can wire it in the the handbrake switch but your making work for yourself. Just don't play video related media whilst driving as it's illegal. Rolling Eyes _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #258055 11th Aug 2013 10:44pm
adseybear
Canada
jont wrote:
So how does this fit in a Td5 dash? 2003 Defender 90 Td5 CSW Belize Green - "Betty"
1958 Series IIA 109 Station Wagon - "Randolph" - Awaiting Restoration
2019 Jeep Wrangler JL Rubicon - SOLD
2006 Volvo V70 D5 - Ocean Race Edition, SOLD
2003 VW Passat Estate 1.9TDI - SOLD
2008 BMW 320D M Sport Estate - SOLD
2001 Defender 90 Td5 Hard Top - SOLD
Post #258065 12th Aug 2013 2:21am
jont
adseybear ... hopefully by hacking away at the dash cover as described in http://www.defender2.net/forum/topic22304.html ... see my post at bottom of first page Confused
rgds
Jon
Post #258082 12th Aug 2013 7:54am
I thought this too as it's a 2DIN HU with a 1DIN slot. As he saidd I assumed he would enlarge it. Thumbs Up _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #258095 12th Aug 2013 9:33am
pjb
rgds
Jon
in my last TD5 an XS I bought the mud dash & just resprayed the whole thing black Thumbs Up 2020 P300 HSE
Post #258099 12th Aug 2013 10:31am
jimbob7
Re: Speakers in
jont wrote:
Also fitted the new Kenwood 3-way speakers today - sounds nice so far Very Happy
Next job to splice in the tweeters ... guess the best place is to cut into the LR>ISO loom ?
Did you buy component speakers?? If you did you will have 4 crossovers (2 per side/speaker) which enable you to fit the supplied tweeters, not sure how you would correctly fit tweeters without crossovers as crossovers divide the signal from the H/U into low frequency (woofers) and high frequency (tweeters).
Of course anything is do-able,but would have thought your tweeters gonna take a beating from the low range frequency.
Post #258149 12th Aug 2013 1:25pm
They aren't components AFAIK.... Mine are currently connected to the standard LR loom. Although not taking the full power they can handle they work well. Because they are so powerful also and high quality it doesn't worry me really running without a x over. The only way other than that would be to Amp them (not sure I would want that because they'd be so loud) and then you could use the x' over's as the power output will be there and take the signals and hardwire them from the original tweeter feed.
All depends on what power they are too but I don't really see the point in screamingly high power on high frequency music. All it will do is make you want to turn it down because it's so loud and pretty much damage your hearing I would imagine if you went to OTT with it.
I have to use mine in this way for now anyway as the HU power output isn't enough to power them anyway. Only get a whisper out of them. _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #258192 12th Aug 2013 4:21pm
barbel jim
jont wrote:
Ta-dah !!
All seems to work - hooked up iPhone to usb to play some music and FM aerial works - need to put DAB aerial on screen and try that too ... only works with ignition on though ?
I quite like the look of that, and it has DAB. Still waiting for an Alpine with 3 4v preouts. Do you have a modle number at all and I can look up specs?
Post #258650 14th Aug 2013 4:34pm
jont
Post #259253 16th Aug 2013 10:27pm
We'll i got my replaced tweeters fitted today and x overs fitted this time too an wow! Shocked very loud crisp and clear. Mr. Green _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #267927 19th Sep 2013 5:52pm
Tiger
Jont you have a PM
Post #267938 19th Sep 2013 7:03pm
