Home > Maintenance & Modifications > Rear Crossmember Coating/Paint/Rustproofing..
Cheshire110
so my rear crossmember looks like this...
and i want to touch it up. Im at my uncles house in a few days, and he has all the masking/spraying/priming eqpmt needed and im wondering whats the best thing to do?
Ill waxoyl the inside and sand back a bit, any recommendations on paint?
was thinking stonechip or is that too 'soft' - ive also never seen how the finish is over a large flat area?
hammerite metal paint maybe?
PS. Is it common that rear X members have 'thinning' paint? seen a few around.
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Cheers, David
Post #256037 3rd Aug 2013 8:42pm
Happyoldgit
Re: Rear Crossmember Coating/Paint/Rustproofing..
Quite common as the finish is so thin, it usually responds to a wipe over with one of the waxy rust inhibitors but the effect wears off after a time. Personally I wouldn't use stone chip on a late model Defender X member, nor would I soil it with Hammerite which is quite a brittle finish once it dries. My choice would be for refinishing in a decent satin black which will look stock and professional. Steve.
Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades.
Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone.
http://forums.lr4x4.com
Post #256047 3rd Aug 2013 9:07pm
Cheshire110
When you say satin black do you mean just a halfords aerosol? Would you use a primer? Cheers, David
Post #256056 3rd Aug 2013 9:34pm
Happyoldgit
I've got a litre tin, compressor, masking tape etc so that's what I'd use but if you don't have the paint a decent rattle can or two will do the job. I would rub down, prime then topcoat. Steve.
Post #256059 3rd Aug 2013 9:40pm
Cheshire110
Yes, sounds like a good plan! Cheers for advice Smile Cheers, David
Post #256062 3rd Aug 2013 9:42pm
bear100
It's still covered by land rovers 6 year anticorrosion warranty Whistle Mines in at the moment having a few things done including new mud flap brackets
Thumbs Up 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #256083 3rd Aug 2013 10:26pm
Cheshire110
Thumbs Up
I've had those done too, but don't see what they can do about the Xmember? Has anyone had it done under corrosion warranty? Cheers, David
Post #256092 3rd Aug 2013 10:46pm
Sonarmender
England 2015 Defender 90 Puma 2.2 HT Corris Grey
Don't know about the Landrover warranty but I would do it like this
1. Remove tow-bar.
2. Lightly rub all areas that you are going to paint with a red scotch brite, soaked in water or panel wipe (provides a key for primer).
3. Mask of all areas you don't wish to paint or get overspray on
4. Use a degreaser (panel wipe) to clean all areas to be painted.
5. Apply a couple of coats of either red oxide or zinc oxide (acts as primer and helps with corrosion protection. (allow 10 mins between coats)).
6. Apply 4 coats of matt or gloss, (your own preference) black aerosol paint or more if you need to, remember light coats are better so you don't get paint sag. ( pay the extra for good quality aerosol as cheap ones contain less paint pigment).
Almost forgot, paints like hammerite are okay, but don't tend to spray as well as cellulose type aerosols, and once on can be a pig to repaint, as they tend to react with almost anything, even hammerite.
Don't forget the dust mask or better still a respirator. Rolling with laughter
Stand back and admire a job well done. Thumbs Up
Any probs you can always PM me. You only have one life, live it....forget the cost.
90XS Hardtop
Post #256100 3rd Aug 2013 11:22pm
Generaldej
United Kingdom 2009 Defender 110 Puma 2.4 CSW Alpine White
I used this satin black spray ( used two cans) which I got from B&Q. I used various grades of wet n dry to remove deep scratches and used the same make primer. Took approx half a day to do. When I got my Landy about a year ago the dealer had done a tarting up job on it with it peeling off in about 6 months and overspray onto the body work.
I removed the handles and sprayed them separately.
I will do the front bumper when I have some spare time.
Post #256101 3rd Aug 2013 11:26pm
Cheshire110
[quote="Sonarmender"]Don't know about the Landrover warranty but I would do it like this
1. Remove tow-bar.
Any probs you can always PM me.[/quote
Very detailed, thanks! Will follow advice and post results on here Cheers, David
Post #256103 3rd Aug 2013 11:38pm
bear100
I think matt black would be my choice Thumbs Up 2023 Defender L663 V8
Post #256123 4th Aug 2013 8:58am
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
My 90 is now over 3 years old and done 38,000. All I do is wipe the rear cross member and front bumper with ACF50 each time I wash it. Still in good condition and NO rust, as yet. Bow down LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #256244 4th Aug 2013 7:26pm
Cheshire110
No rust on mine either, I just want to get a more even paint finish and protect it some more. For some reason LR don't seem to have painted some xmembers very well, and it stands out on my black 110. Cheers, David
Post #256256 4th Aug 2013 7:55pm
adafish
United Kingdom 1984 Defender 110 300 Tdi DCPU Stornoway Grey
Tim @ Mobilecentre had his done by Will @ Sense of Adventure in a Stone Chip spray, turned out really good. Putting Dreams on Drives at JLR Solihull..
Post #256432 5th Aug 2013 6:14pm
Sphere
United Kingdom 2015 Defender 110 Puma 2.2 USW Keswick Green
What's the stone chip like ada as I was going to have mine done when it goes in to have a few scratches done not sure what the best finish is.
Post #256438 5th Aug 2013 6:34pm
