![]() | Home > Maintenance & Modifications > Better breathing |
Mr Baldylocks Member Since: 15 Jul 2010 Location: Nearer my home than yours. Posts: 487 ![]() ![]() ![]() |
Afternoon Peeps
I've been sat here feeling sorry for myself because I've hurt my back ![]() ![]() ![]() ![]() Thanks for your help and I look forward to hearing your views on it ![]() |
That's my thoughts diesel_jim, I don't go off road and I figure it should work
If you have not already done so, get rid of the water separator/cyclone up by the air box - it makes a lot of difference
![]() Not the easiest of tasks and probably best to wait until your back has healed. Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
That's the next job Bob, I think that I'll do that when I try the pipe mod. Who remapped your TD5 and which stage
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6208 ![]() ![]() ![]() |
I did the same... seemed to make the same difference as removing the snorkel, so it shows that it lets the engine breathe better. |
Not had mine mapped - yet
![]() When it gets done I will get West Somerset LR to put an Alive stage one on. It is in next week for a new clutch and DMF - DMF is on its way out and I think it is best to be done before it expires off road ![]() Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
Norm4n Member Since: 31 Aug 2012 Location: Surrey Posts: 329 ![]() ![]() |
Isn't that little propeller there for a reason?
It is supposed to remove moisture/water from the input air stream. If you have a snorkel fitted it is not really doing anything.
I've was lead to believe the cyclone thingy is to help provide air flow across the filter and hence spreading the muck across it (ie to try and avoid a build up of muck in air area)?
If so, for the sake of a bit more BHP i'd happily change the filter more often. It's not like they're expensive.
Could always just rotate the filter mid way between services if it bothered you that much, to spread the "wear" around. |
