Home > Maintenance & Modifications > Better breathing
Mr Baldylocks
United Kingdom 2002 Defender 90 Td5 CSW Bonatti Grey
Better breathing
Afternoon Peeps
I've been sat here feeling sorry for myself because I've hurt my back Big Cry Still every cloud has a silver lining so I've been swatting up on the TD5 section and read what I could on tuning Twisted Evil Twisted Evil my question for the technically minded is, I have a MOD style snorkel but have read that these restrict airflow dramatically so if I attached 80mm flexi pipe from the base of the snorkel and got rid of the restriction that is attached to the inner part of the wing and connected it directly to the air box would that eliminate the vehicle gasping for air Question in my basic little mind I think that it'll work but I'm sure that someone here has already done it, I would also be taking in air away from the engine so should be cooler as well.
Thanks for your help and I look forward to hearing your views on it Thumbs Up Life is one big adventure, that's why we have the vehicle for the journey.
Post #253292 23rd Jul 2013 3:57pm
As they say... every little helps!
On my 110, unless I know i'm going wading/off roading, I just undo the flexi pipe off the bottom of the snorkel (under the wing) and wedge it to suck in straight through the grill, thus eliminating the snorkel upright pipe altogether.
Makes a bit of difference.
Post #253298 23rd Jul 2013 4:17pm
Mr Baldylocks
That's my thoughts diesel_jim, I don't go off road and I figure it should work Neutral Life is one big adventure, that's why we have the vehicle for the journey.
Post #253300 23rd Jul 2013 4:21pm
bob neville
If you have not already done so, get rid of the water separator/cyclone up by the air box - it makes a lot of difference Thumbs Up
Not the easiest of tasks and probably best to wait until your back has healed.
2013 Defender 90 CSW - sold
Post #253317 23rd Jul 2013 5:54pm
Mr Baldylocks
That's the next job Bob, I think that I'll do that when I try the pipe mod. Who remapped your TD5 and which stage Question Life is one big adventure, that's why we have the vehicle for the journey.
Post #253318 23rd Jul 2013 5:57pm
I did the same... seemed to make the same difference as removing the snorkel, so it shows that it lets the engine breathe better.
Post #253322 23rd Jul 2013 6:12pm
bob neville
Not had mine mapped - yet Thumbs Up
When it gets done I will get West Somerset LR to put an Alive stage one on.
It is in next week for a new clutch and DMF - DMF is on its way out and I think it is best to be done before it expires off road Shocked
Post #253325 23rd Jul 2013 6:42pm
Norm4n
Isn't that little propeller there for a reason?
Post #253367 23rd Jul 2013 9:06pm
bob neville
It is supposed to remove moisture/water from the input air stream. If you have a snorkel fitted it is not really doing anything.
Post #253399 24th Jul 2013 7:12am
Caterham
I've was lead to believe the cyclone thingy is to help provide air flow across the filter and hence spreading the muck across it (ie to try and avoid a build up of muck in air area)?
Post #253447 24th Jul 2013 11:32am
If so, for the sake of a bit more BHP i'd happily change the filter more often. It's not like they're expensive.
Could always just rotate the filter mid way between services if it bothered you that much, to spread the "wear" around.
Post #253519 24th Jul 2013 6:58pm
