Home > Maintenance & Modifications > Installing a aux power socket in the rear |
TheWarden Member Since: 25 Feb 2013 Location: Southampton Posts: 179 |
if it's still the, the mod can be done, but just requires a bit more work.... something to investigate I think as a rear aux socket would be very useful 2013 Aintree Green 110 Station Wagon SX
30th Jun 2013 6:42pm |
mobilecentre Member Since: 05 Mar 2012 Location: Evesham Posts: 645 |
Purple wire can be seen on right hand side of plug |
30th Jun 2013 6:47pm |
Martin 01 Member Since: 13 Feb 2012 Location: East Yorkshire Posts: 500 |
Just fitted a couple of 12v sockets in to mine ready for the summer.
Just don't know why land rover do not fit them as standard. Thanks for the tip on finding the cable. |
6th Jul 2013 8:32pm |
DiscoStu Member Since: 30 Jun 2007 Location: London/The far north Posts: 253 |
Will removing the rear speaker panel (drivers side) expose this loom, or do I need to look elsewhere? My Disco 'best bits' Defender 110 XS CSW 2013 |
7th Jul 2013 6:51am |
Paul55 Member Since: 03 Feb 2009 Location: Somewhere in my head! Posts: 510 |
removed my speaker and the loom was just to the left hand side. Cogito ergo sum |
7th Jul 2013 9:18am |
Thank you My Disco 'best bits'
7th Jul 2013 9:33am |
Swollock Member Since: 16 Mar 2013 Location: Wellingborough Northants Posts: 259 |
Thanks for this, was about to try and fit one myself. Save me no end of trouble as was looking at running cable into the back.
Tony 2008 Defender 110 XS CSW Volvo S60 T8 Triumph 1200 Rally Explorer G0UBX |
7th Jul 2013 10:39am |
Which fuse is it connected to ?
Think I've just blown it testing my fridge out. Plugged fridge in & nothing until ignition on. Ran for a short while then went off. No power now at the sockets. Any ideas ? Martin |
8th Jul 2013 8:02pm |
Forgot to say its a 2002 110 CSW.
Looked at all fuses and they all seem ok. I'm a little lost. Any answers ? |
8th Jul 2013 10:23pm |
Martin,
The purple wire goes back to fuse 2 (20Amp) under the RH side seat. It also protects the towing socket. At least that is so on a Puma. Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
9th Jul 2013 5:43am |
I have taken a look this morning Eric and found a blown fuse under the drivers seat. It was a 15amp one. I have replaced that one but still no power at socket. Checked all other fuses and they are all ok. Any other suggestions ? |
9th Jul 2013 7:33am |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 |
Recheck fuse 2 which should be 30amp and power accessory wiring to rear, trailer power and interior lights. The only 15amp fuse under the drivers seat is fuse 6 Alarm system, according to Dgardels Users Handbook for a td5. LANDYWATCH
Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
9th Jul 2013 8:37pm |
Welshgas,
Checked that fuse & all is ok. Interior lights all ok. Plugged my caravan into the towing socket & all is working. I'm a little baffled. All fuses are ok after checking. Any ideas ? |
9th Jul 2013 9:02pm |
Some in-line fuse maybe?
Use multimeter to check continuity of +tve or earth. LANDYWATCH Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
9th Jul 2013 9:11pm |
