![]() | Home > Td5 > TD5 ECU advice requested |
When you say have you done the usual things does that include the injector harness (or checking for oil in the injector harness) - red plug on ecu, disconnect etc ?
Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
Macpaul Member Since: 26 Mar 2013 Location: SW Surrey Posts: 439 ![]() ![]() ![]() |
Yes, injector harness has been done.
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 ![]() ![]() ![]() |
Has it been remapped ? It may be over boosting 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
Yes, it's been remapped but has a boost box fitted.
It had the problem both before and after the remap. I know the ECU is at the end of the list as far as solving the problem is concerned but I've: 1. Changed the MAF (genuine) 2. Cleaned the MAP 3. Changed the injector harness + cleaned out repeatedly 4. Had 5 new injectors after previous ones were tested and condemned. 5. Wound the wastegate right off So does anyone got any info on the compatibility of an NNN000120 ECU with my existing NNW500930 part number? Thanks |
Throttle potentiometer, maybe? Darren
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1454 ![]() ![]() ![]() |
Sorry I don't want to sound rude, but who remaps a vehicle that is not running right ??? And hands it back as a finished job ??? So you paid £500+ for a map that dose not work ?? ![]() ![]() |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6021 ![]() ![]() ![]() |
Fuel pressure dropping off?
Blocked air intake reducing air flow or turbo hoses getting hot and collapsing or expanding too much and not keeping the pressure up? Any odd noises? 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6208 ![]() ![]() ![]() |
Everyone seems to have mentioned the obvious things to check, but regarding the ECU's, yes, you'll need either an NNN500020 or NNN000120 for your defender.
Either can be reflashed to defender settings. With thanks to Pete @ Bell autos, he's advised for a 10P engine (not sure what yours is... at 2003 it's probably a 15P) but for 10P the standard fuelling files are: you can use, on an eu2 (10P) engine, NNN500020 or NNN000120 with NNN000120, use STHLE022 & STTLP009 (euro defender non A/C) with NNN500020, use STHLE022 & STTLP010 (euro defender non A/C) Looking on my nanocom map wizard, for later defenders NNN000120 use svlne007 & svtnp005 (euro defender) NNN500020 use svlne007 & svtnp006 (euro defender) There's a couple of NNN000120's on ebay at the moment, i'm watching one as I need one for the project90. currently at about £130 with 4 days to go, so expect about £200 ish. |
Replaced it already thanks. |
Fuel pressure checked and OK. Air intake and turbo hoses checked and OK. No odd noises. Sounds great actually. |
If you think ECU, maybe one of the tuners might lend you one to test? 1999 Defender TD5 110
Fair question and just the sort of reply I might have made but I'd rather not say at this stage as he's not given up. I'm just looking at worst case. |
Yes mine's a 15P but from what I gather from your post, the NNN000120 would be OK for that .....? |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8379 ![]() ![]() ![]() |
if you have a gen MAF was it mapped to a gen one? although doesnt account for it being wrong prior.
so 60psi in the fuel line then? can you not just borrow a ecu and see how it goes. injectors wont be matched but it will run. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
