Home > Td5 > TD5 ECU advice requested
Macpaul
United Kingdom 2013 Defender 110 Puma 2.2 USW Loire Blue
Morning All,
I have a 2003 TD5 with the problem that on every run it goes into a semi-limp mode, that is, a flat throttle but not a full-on limp and no error codes are shown or recorded.
Having done lots of the usual stuff, MAF, MAP etc to no effect, I'm left with the possibility that there's something wrong with the ECU. Not common I understand but there we are and I'm getting near the end of my tether with this thing.
The possibility exists of buying one, part number NNN000120.
Mine is marked NNW500930 4195.
As I read the searches here, any NN ECU is re-codeable/flashable and should be a replacement for mine but before I start spending money, can anyone tell me if this is true?
Many thanks....
Post #235671 15th May 2013 11:58am
bob neville
When you say have you done the usual things does that include the injector harness (or checking for oil in the injector harness) - red plug on ecu, disconnect etc ?
2013 Defender 90 CSW - sold
Post #235674 15th May 2013 12:10pm
Macpaul
Yes, injector harness has been done.
Post #235679 15th May 2013 12:28pm
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
Has it been remapped ? It may be over boosting 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #235684 15th May 2013 12:37pm
Macpaul
Yes, it's been remapped but has a boost box fitted.
It had the problem both before and after the remap.
I know the ECU is at the end of the list as far as solving the problem is concerned but I've:
1. Changed the MAF (genuine)
2. Cleaned the MAP
3. Changed the injector harness + cleaned out repeatedly
4. Had 5 new injectors after previous ones were tested and condemned.
5. Wound the wastegate right off
So does anyone got any info on the compatibility of an NNN000120 ECU with my existing NNW500930 part number?
Thanks
Post #235690 15th May 2013 12:48pm
Throttle potentiometer, maybe? Darren
Post #235693 15th May 2013 12:52pm
barbel jim
2. Cleaned the MAP
Thanks
Sorry I don't want to sound rude, but who remaps a vehicle that is not running right ??? And hands it back as a finished job ??? So you paid £500+ for a map that dose not work ?? Thud Banging Head Did the tuner not have any ideas ?? Or was he too busy counting your hard earned ??
Post #235696 15th May 2013 1:03pm
excossack
Fuel pressure dropping off?
Blocked air intake reducing air flow or turbo hoses getting hot and collapsing or expanding too much and not keeping the pressure up?
Any odd noises? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #235699 15th May 2013 1:07pm
Everyone seems to have mentioned the obvious things to check, but regarding the ECU's, yes, you'll need either an NNN500020 or NNN000120 for your defender.
Either can be reflashed to defender settings.
With thanks to Pete @ Bell autos, he's advised for a 10P engine (not sure what yours is... at 2003 it's probably a 15P) but for 10P the standard fuelling files are:
you can use, on an eu2 (10P) engine, NNN500020 or NNN000120
with NNN000120, use STHLE022 & STTLP009 (euro defender non A/C)
with NNN500020, use STHLE022 & STTLP010 (euro defender non A/C)
Looking on my nanocom map wizard, for later defenders
NNN000120 use svlne007 & svtnp005 (euro defender)
NNN500020 use svlne007 & svtnp006 (euro defender)
There's a couple of NNN000120's on ebay at the moment, i'm watching one as I need one for the project90. currently at about £130 with 4 days to go, so expect about £200 ish.
Post #235712 15th May 2013 1:42pm
Macpaul
Replaced it already thanks.
Post #235723 15th May 2013 2:08pm
Macpaul
Any odd noises?
Fuel pressure checked and OK.
Air intake and turbo hoses checked and OK.
No odd noises. Sounds great actually.
Post #235724 15th May 2013 2:10pm
excossack
If you think ECU, maybe one of the tuners might lend you one to test? 1999 Defender TD5 110
Regards
John M0VAZ
Post #235726 15th May 2013 2:11pm
Macpaul
Fair question and just the sort of reply I might have made but I'd rather not say at this stage as he's not given up.
I'm just looking at worst case.
Post #235727 15th May 2013 2:13pm
Macpaul
Yes mine's a 15P but from what I gather from your post, the NNN000120 would be OK for that .....?
Post #235731 15th May 2013 2:17pm
jst
if you have a gen MAF was it mapped to a gen one? although doesnt account for it being wrong prior.
so 60psi in the fuel line then?
can you not just borrow a ecu and see how it goes. injectors wont be matched but it will run. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #235735 15th May 2013 2:26pm
