![]() | Home > Maintenance & Modifications > Rear LED lights |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6682 ![]() ![]() ![]() |
The only CAN bus is between the engine ECU and the instrument pack, the lights are definitely not controlled by it!!
fusionfanatic Member Since: 11 Apr 2013 Location: north norfolk Posts: 40 ![]() ![]() |
Even so is there an issue due to the way the vehicle checks the bulbs for failure which means they wont work?
Plenty on here running LED lamps, suggest a search and a read
macduff Member Since: 04 Nov 2012 Location: NE Posts: 119 ![]() ![]() |
No bulb checks on the defender that I've seen on my 08 110. Except for those done by eye of course... 2023 110 P400e |
That's interesting, The guy in there was showing me all the wipac LED NAS style replacement lights and said they have had problems with them as I mentioned, I don't have one that age either but Just thought I'd ask the question, did a quick forum search. Again its not like its an issue I am posed with directly just thought I would ask the question. I will clarify next time I speak to them. |
Kitoper Member Since: 07 Dec 2012 Location: Geneva Posts: 204 ![]() ![]() |
Same for me, I have installed RDX led lights for my Defender and have had no issues on the Brake and parking lights. For the indicators, you will need to change the relay which is included in the package I purchased from BoltonBits. [url]http://www.ebay.co.uk/itm/8-RDX-LED-STANDARD-SIZE-Light-lamps-Relay-ONLY-Defender-Td5-Tdci-Red-Clear-/390549817265?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item5aee9547b1[url] ![]() Click image to enlarge[/url] |
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 ![]() ![]() ![]() |
Xtech comes with LED's as standard, there is no issue with them
![]() ![]() www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
william8 Member Since: 03 Apr 2013 Location: Motherwell Posts: 259 ![]() ![]() ![]() |
Would i be right in saying that the lights/wipers/central locking and stereo etc, are still wired just like they used to be back in the 80's. Because i haven't seen much difference. I have a c regi and its the exact same wiring at the back than my 08 puma
Yes William, pretty much
Well at least the laws of electronics haven't changed since then
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20912 ![]() ![]() |
Probably because the LED's are / were one way polarity and will not work reversed. An incandescent (filmament type) bulb will light up regardless of polarity whether correct or reversed. My interior LED's I'm putting in are like that. ![]() ___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Correct about Xtech (and SVX, FIRE/ICE, etc.) but not the turn signals. On all those the turn signals ex factory remain incandescent 21W bulbs. Some (me ![]() ![]() http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 ![]() ![]() ![]() |
what do LR use on Xtech etc for LEDs? Are they RDX? BM52
They use these... made by Le Perei, which believe is a UK manufacturer. The pic below shows them after I have changed the standard bulb powered turn signal by a Le Perei LED of the same series as the other LEDs Land Rover use on the SVX, ICE, Xtech, etc.
![]() Click image to enlarge You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
