Home > Maintenance & Modifications > Rear LED lights
fusionfanatic
Rear LED lights
I have been told by my auto electrical place that LED rear lights cannot be fitted 06-09 due to them being controlled by the CAN bus, apparently they pulse all the time and come up on the dash as faulty.
Does anyone else have a solution for this issue or even experienced it?
Post #234359 10th May 2013 1:46pm
Martin
Site Admin
The only CAN bus is between the engine ECU and the instrument pack, the lights are definitely not controlled by it!!  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #234360 10th May 2013 1:48pm
fusionfanatic
Even so is there an issue due to the way the vehicle checks the bulbs for failure which means they wont work?
Post #234361 10th May 2013 1:49pm
Martin
Site Admin
Plenty on here running LED lamps, suggest a search and a read Mr. Green  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #234362 10th May 2013 1:52pm
macduff
No bulb checks on the defender that I've seen on my 08 110. Except for those done by eye of course... 2023 110 P400e
Post #234364 10th May 2013 1:53pm
fusionfanatic
That's interesting, The guy in there was showing me all the wipac LED NAS style replacement lights and said they have had problems with them as I mentioned, I don't have one that age either but Just thought I'd ask the question, did a quick forum search.
Again its not like its an issue I am posed with directly just thought I would ask the question. I will clarify next time I speak to them.
Post #234366 10th May 2013 1:59pm
Kitoper
Switzerland
Same for me, I have installed RDX led lights for my Defender and have had no issues on the Brake and parking lights. For the indicators, you will need to change the relay which is included in the package I purchased from BoltonBits.
[url]http://www.ebay.co.uk/itm/8-RDX-LED-STANDARD-SIZE-Light-lamps-Relay-ONLY-Defender-Td5-Tdci-Red-Clear-/390549817265?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item5aee9547b1[url]
[/url]
Post #234367 10th May 2013 2:00pm
Killer90
Site Sponsor
Xtech comes with LED's as standard, there is no issue with them Thumbs Up The only problem i have ever come across was on an older vehicle were we fitted a set of led sidelights and the wires needed swapping over so red went to black and vise versa Wink CSK Automotive
www.cskautomotive.co.uk
Post #234370 10th May 2013 2:09pm
william8
Scotland 2008 Defender 90 Puma 2.4 XS CSW Zambezi Silver
Would i be right in saying that the lights/wipers/central locking and stereo etc, are still wired just like they used to be back in the 80's. Because i haven't seen much difference. I have a c regi and its the exact same wiring at the back than my 08 puma Smile Its just the engine that gets changed. William
Post #234375 10th May 2013 2:34pm
Martin
Site Admin
Yes William, pretty much Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #234376 10th May 2013 2:37pm
william8
Well at least the laws of electronics haven't changed since then Laughing William
Post #234385 10th May 2013 3:34pm
Probably because the LED's are / were one way polarity and will not work reversed. An incandescent (filmament type) bulb will light up regardless of polarity whether correct or reversed. My interior LED's I'm putting in are like that.
Thumbs Up _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #234402 10th May 2013 5:35pm
ericvv
Correct about Xtech (and SVX, FIRE/ICE, etc.) but not the turn signals. On all those the turn signals ex factory remain incandescent 21W bulbs. Some (me Laughing ) have changed those to same looking LEDs which you can buy for instance from Mobilecentre. In the case where you make this change, you indeed have to change the turn signal relay by one from either Mobilecentre or by one from RDX BoltonBits. The latter as a matter of fact is a more sophisticated relay as it has the audible signal plus a few more advantages. In any way, no '06 onward Defenders should have any trouble running LED lamps. My SVX is a '09 model and I have LEDs virtually all over and they work a treat Thumbs Up You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #234456 10th May 2013 8:56pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
what do LR use on Xtech etc for LEDs? Are they RDX? BM52
Post #234464 10th May 2013 9:16pm
ericvv
They use these... made by Le Perei, which believe is a UK manufacturer. The pic below shows them after I have changed the standard bulb powered turn signal by a Le Perei LED of the same series as the other LEDs Land Rover use on the SVX, ICE, Xtech, etc.
Post #234468 10th May 2013 9:21pm
