Home > Maintenance & Modifications > Soundproofing a Defender
Page 6 of 9 <123456789>
SGH
I'll cross that bridge when I come to it Laughing but unless you need to remove the inner panel that bolts to the door frame it should not be too bad a job.
Post #233443 7th May 2013 3:24pm
superspoons
England 1998 Defender 90 V8 Petrol 50th Auto Atlantis Blue
airpusher wrote:
What's it like to remove if required? I was looking at SGH gallery and the doors, if I need to remove it for any reason is it difficult?
After doing the floor / arch's of my 110 last weekend.... once it goes down, I can't see you getting it up easily. Not a bad thing of course but just a warning to get it right first time Smile Cheers,
Superspoons
Post #233446 7th May 2013 3:32pm
Killer90
Site Sponsor
Gavin- I cut a square sheet and stuck it in place of the LR cheap sound deadening Laughing then i just done little bits on the shaped parts of the metal piece mainly to stop vibration Thumbs Up You can plonk it on how you liek as it will do the same job just i like to keep it neat Thumbs Up CSK Automotive
www.cskautomotive.co.uk
Post #233511 7th May 2013 5:38pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
Quick Q - how much space is there between the door card and the inner panel. Could you fit acoustic foam in between? BM52
Post #233532 7th May 2013 6:47pm
superspoons
Cheers Chris - doors to do after the roof Smile Cheers,
Superspoons
Post #233538 7th May 2013 7:00pm
Luismi
Spain 2004 Defender 110 Td5 SW Alpine White
HTH
Post #233603 7th May 2013 8:43pm
Sphere
United Kingdom 2015 Defender 110 Puma 2.2 USW Keswick Green
Been reading this thread with interest as about to sound proof my td5 double cab. Really it's getting rid if the wet naff carpet with the wright off road kit to smarten it up and improve practicability front and rear so seats etc has to come out.
The sound proofing is a welcome benefit however after reading this wondering if I should dynamat as well if so where and how much. I realise its a where do you stop however interested to see what people think would be reasonable and worth while without spending a fortune (I already have on the matting)
Post #233620 7th May 2013 9:14pm
Killer90
Site Sponsor
I would say soundproof the front floor and seat box, also the middle row floor and seat box, a bit on the door inners and job done Thumbs Up You could always go for Dynadeck instead of carpet as it doesnt absorb water and have a nice grained finish to it Thumbs Up CSK Automotive
Post #233624 7th May 2013 9:18pm
Sphere
Pretty much all of it then Laughing
How much would I need for this?
Think it would be dynamat as have already bought the wright off road kit
Post #233635 7th May 2013 9:50pm
Killer90
Site Sponsor
I would say 1 pack if you measure it out correctly Thumbs Up CSK Automotive
Post #233648 7th May 2013 10:07pm
pesto_trader
Norway 2005 Defender 90 Td5 SW Tonga Green
Nice job! Im doing my 90 td5 at the moment. I have just removed the panel on the front door on the drivers side. Should i take off the plastic insulation or just cover the door as it is now?
Post #251553 15th Jul 2013 9:00pm
Killer90
Site Sponsor
Thumbs Up thank you, strip off the original door shredder and you can replace it with Dynaliner Thumbs Up or take it off carefully, dynamat behind and replace Mr. Green CSK Automotive
Post #251563 15th Jul 2013 9:37pm
Les Brock
Just lined my roof with 3mm Butyl sound deadening and insulated with this stuff, 10mm closed cell foam is it worth adding another layer ?
Only used about half the roll and I have aanother full roll as well
waiting for alloy tape to seal it all up
Regards
Les
Post #256326 5th Aug 2013 9:30am
geobloke
That is a great job you have done there Les. I doubt a second layer is going to do very much more for you than the first has already. Can you use the extra roll anywhere else in your 90?
Post #256327 5th Aug 2013 9:37am
Les Brock
Yes still got the sides to do, tub etc but didnt use as much as I thought I would Laughing
Regards
Les
Post #256328 5th Aug 2013 9:41am
