![]() | Home > Maintenance & Modifications > Soundproofing a Defender |
superspoons Member Since: 16 Apr 2012 Location: Herts Posts: 314 ![]() ![]() ![]() |
After doing the floor / arch's of my 110 last weekend.... once it goes down, I can't see you getting it up easily. Not a bad thing of course but just a warning to get it right first time ![]() Superspoons |
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 ![]() ![]() ![]() |
Gavin- I cut a square sheet and stuck it in place of the LR cheap sound deadening
![]() ![]() ![]() www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 ![]() ![]() ![]() |
Quick Q - how much space is there between the door card and the inner panel. Could you fit acoustic foam in between? BM52
Cheers Chris - doors to do after the roof ![]() Superspoons |
Luismi Member Since: 04 Nov 2010 Location: Cotswolds Posts: 178 ![]() ![]() ![]() |
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge HTH |
Sphere Member Since: 26 Apr 2013 Location: Midlands Posts: 725 ![]() ![]() ![]() |
Been reading this thread with interest as about to sound proof my td5 double cab. Really it's getting rid if the wet naff carpet with the wright off road kit to smarten it up and improve practicability front and rear so seats etc has to come out.
The sound proofing is a welcome benefit however after reading this wondering if I should dynamat as well if so where and how much. I realise its a where do you stop however interested to see what people think would be reasonable and worth while without spending a fortune (I already have on the matting) |
I would say soundproof the front floor and seat box, also the middle row floor and seat box, a bit on the door inners and job done ![]() ![]() www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
Pretty much all of it then ![]() How much would I need for this? Think it would be dynamat as have already bought the wright off road kit |
I would say 1 pack if you measure it out correctly
pesto_trader Member Since: 26 Jun 2013 Location: Oslo Posts: 148 ![]() ![]() ![]() |
Nice job! Im doing my 90 td5 at the moment. I have just removed the panel on the front door on the drivers side. Should i take off the plastic insulation or just cover the door as it is now?
Les Brock Member Since: 20 Mar 2012 Location: Stroud, Glos Posts: 187 ![]() ![]() |
Just lined my roof with 3mm Butyl sound deadening and insulated with this stuff, 10mm closed cell foam is it worth adding another layer ?
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Only used about half the roll and I have aanother full roll as well waiting for alloy tape to seal it all up Regards Les Last edited by Les Brock on 5th Aug 2013 9:39am. Edited 1 time in total |
That is a great job you have done there Les. I doubt a second layer is going to do very much more for you than the first has already. Can you use the extra roll anywhere else in your 90?
Yes still got the sides to do, tub etc but didnt use as much as I thought I would ![]() Regards Les |
