Page 498 of 1390 <123 ... 497498499 ... 138813891390>
sparkylee
2012 Defender 110 Puma 2.2 DCPU Santorini Black
(I never knew the EGR valve made noises when you shut down till I stood by the front after my partner had arrived home one eve Rolling with laughter !)[/quote]
Never heard mine either Rolling with laughter It's good to be back from the dark side
DC110 -2012 Black with black hood and black x-tech
FFRR 4.2 vogue
Renault traffic auto
PT crusier convertible
Laika x700 Motorhome
Post #232086 1st May 2013 8:13pm
JWL
I know it's not the heat shield, I've repaired that allready. The rattle is there only on roughish roads and whilst moving. It's not the brakepads, still rattles under light and heavy braking. I've replaced the suspension bushes, new shock absorbers, nothing seems to be falling off so in the words of Toyah; it's a mystery!
Post #232093 1st May 2013 8:53pm
db950
United Kingdom 1997 Defender 110 300 Tdi HT Nato Green
Fitted a new bilstein steering damper hoping it tames the steering a bit!!
Next on the list would be a steering box so thought I would try the cheaper option first.
I've also got an intermittent rattle, very annoying, seems to be behind the dash on the l/h side so might be the wiper motor, but very difficult to pin point when driving. 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html
2014 Discovery 4 SE Tech
Instagram @the110camper
Post #232115 1st May 2013 9:44pm
Zinke
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
Could be the bonnet hinge, mine did that and i would swear it was coming from inside but it was the hinge. i wrapped the bush with a little tape which got rid of the noise, i will be ordering some heavy duty hinges soon.
Pete.
Post #232207 2nd May 2013 10:31am
mk1collector
Same here as per post on last page Thumbs Up with the bonnet closed try banging your fist on the top of the bonnet near the hinge and if it rattles replace the bushes and check the sealer between the bonnet skin and frame for splits and replace as necessary Thumbs Up
Post #232209 2nd May 2013 10:51am
db950
Thanks both, have got new bushes and seal on the bonnet but still could be play in the hinge, will have to investigate but seem to forget then get driving and think must get that sorted! 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html
Post #232214 2nd May 2013 11:10am
sparkylee
Lovely day for a drive to Nene Overland to collect awning and have a mooch around
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  It's good to be back from the dark side
FFRR 4.2 vogue
Post #232255 2nd May 2013 5:13pm
my polishing machine arrived today ... Thumbs Up
Post #232284 2nd May 2013 8:01pm
tookaphotoof
Netherlands 2013 Defender 130 Puma 2.2 HCPU Santorini Black
Drove around to local shops to source parts for the Caterham... Rolling Eyes
Post #232285 2nd May 2013 8:04pm
mk1collector
Productive day again Mr. Green another rattle defeated and a wiring problem sorted that turned out to be a previous owners bodge Evil or Very Mad still at least it was an easy and cheap fix and I have working rear washer jet now Thumbs Up
Post #232286 2nd May 2013 8:08pm
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
Finally managed to fit my toughbook car mount and remote touchscreen, also fitted a new rod rack to the roof lining
 Original Member Pie n Pea Club.
110 HCPU Tipper
Post #232298 2nd May 2013 8:44pm
VeeTee
Netherlands
Did the variable wiper mod (Old thread, but thanks Dgardel Thumbs Up ) and also installed a Engine Check temp meter:
 Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #232331 2nd May 2013 10:06pm
excossack
That's a neat way of storing fishing roads.
What screen have you used? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #232334 2nd May 2013 10:12pm
shaun.mobile
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Fuji White
[quote="willy eckerslike"]Finally managed to fit my toughbook car mount and remote touchscreen, also fitted a new rod rack to the roof lining
Bow down Bow down Bow down you've got to be pleased with almost 7500 responses on this post you started.
anyway, what software are you running on that screen? I use google maps on my xda flint for navigation but wouldn't mind looking at a better alternative. I don't want a voice telling when to turn left or when to indicate etc, just a good map.
are you running that screen from the Toughbook?
Post #232388 3rd May 2013 9:26am
excossack
That looks like Memory Map to me? 1999 Defender TD5 110
Regards
John M0VAZ
Post #232390 3rd May 2013 9:30am
