![]() | Home > Tdi > Hi all ....... Just bought a Lemon |
lambert.the.farmer Member Since: 11 Apr 2012 Location: harrogate Posts: 2006 ![]() ![]() ![]() |
Consider yourself lucky when i bought mine off a reputable dealer FRIEND i spent 3 k more than you and had no better a car at te end even after the limited amount of work was done under the warranty i got i still ended up nearly 2 grand further into the hole to get the car to the standard it should have been for the price i paid for it. Rhubarb and custard let fly with their secret weapon.
Rusty Spanner Member Since: 24 Apr 2013 Location: Liverpool Posts: 24 ![]() |
Not much of a FRIEND then
bcarlin Member Since: 24 Sep 2011 Location: lanarkshire Posts: 290 ![]() ![]() |
If the guy selling doesn't know the chassis is bad its up to you to get an independent inspection done on the motor or for you to have a good poke about it before buying it.you may be 5k out of pocket at the moment but the motor isn't getting scrapped so you will get money back on it once its fixed or even get some money back the way it is. Anyone who is buying an older defender should check the chassis themselves as its well know how long they last before needing welding or replaced.
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8365 ![]() ![]() ![]() |
i would just fix it and put it down as one of those things. more important things in life to worry about. Cheers
If I sold you something described as excellent I would make sure it was excellent and if it wasn't Id offer your money back . Although I believe Keith new nothing about the chassis, that's something I will never know for sure, I do know one thing though I'll never buy another car with a short mot . Keith's offered a small gesture and I've accepted so that's the end of the matter .............. I cant say I'm ecstatic with my new purchase .And just because your buying a Defender doesn't mean you should accept ![]() At least its going to get a proper repair this time |
