Home > Technical > TD5 rocker gaskets.
excossack
TD5 rocker gaskets.
My understanding there are two gaskets available, early one and a later one.
What are the differences?
I am still chasing the oil leaks and yesterday after a 40 min drive I popped the bonnet to check for leaks and spotted a tiny wisp of fumes coming from the rear of the rocker gasket.
Which got me wondering if the later gaskets have a slightly bigger half moon section? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #227082 14th Apr 2013 10:03am
When i fitted the new head to my 90, twice... i just used some gasket sealer either side of said rocker gasket... no leaks at all Thumbs Up
Post #227093 14th Apr 2013 10:43am
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
Earlier td5 gaskets do have a smaller Half moon section if you've fitted the earlier type it will leak like anything !
Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #227111 14th Apr 2013 11:36am
barbel jim
I only did the half moons with RV silicon and have had the same result Thumbs Up
Post #227126 14th Apr 2013 12:31pm
excossack
You must be the lucky ones!. Would an a later gasket fit an ealier head (mine is an AMC head)? 1999 Defender TD5 110
Regards
John M0VAZ
Post #227132 14th Apr 2013 12:54pm
geobloke
IIRC the rocker cover bolts have to be torqued down to about 7 ftlb, which is not very tight, if you over tighten them the gasket will deform and you will get leaks.
I like the gasket sealer idea though...
Post #227140 14th Apr 2013 1:34pm
