![]() | Home > Technical > TD5 rocker gaskets. |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6208 ![]() ![]() ![]() |
When i fitted the new head to my 90, twice... i just used some gasket sealer either side of said rocker gasket... no leaks at all
derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 567 ![]() ![]() ![]() |
Earlier td5 gaskets do have a smaller Half moon section if you've fitted the earlier type it will leak like anything !
Will 2005 90 XS 1954 86'' Series 1 tilt 1968 88” 2A 200tdi 2002 110 Hardtop |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1454 ![]() ![]() ![]() |
I only did the half moons with RV silicon and have had the same result ![]() |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6021 ![]() ![]() ![]() |
You must be the lucky ones!. Would an a later gasket fit an ealier head (mine is an AMC head)? 1999 Defender TD5 110
IIRC the rocker cover bolts have to be torqued down to about 7 ftlb, which is not very tight, if you over tighten them the gasket will deform and you will get leaks.
I like the gasket sealer idea though... |
