![]() | Home > Technical > 90 losing power |
Green Machine Member Since: 19 Nov 2010 Location: North Yorkshire Posts: 1226 ![]() ![]() ![]() |
http://www.defender2.net/forum/topic17174.html?highlight=speedo
Does this help? 2005 Td5 | 90 Station Wagon | Tonga Green |
![]() Last edited by fekete on 7th Dec 2015 7:49pm. Edited 1 time in total |
No worries - hopefully that's all it is.
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20959 ![]() ![]() |
EGR stuck open could cause a lack of power too. Although likely to put up the MIL or log a DTC though which I assume you've not had. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Small loss of coolant can cause EMS to kick into limp home mode. Temp drops and then full power again.
Brendan |
IF, and I repeat if you have a small loss of coolant do not be fobbed off with main dealer saying it is a weak pressure cap.
Yes they will replace pressure cap foc, however you may have a more serious problem such as a head gasket job. IF you just loss power under load, I.e. hills/towing briefly for less then 30 seconds and NO apparent temperature rise with a small loss of coolant I would strong suspect head gasket. Yes I have that tshirt! Brendan |
Didn't look like you were losing power when you were up my backside coming onto the estate yesterday morning
![]() ![]() Hope you sort it out mate ![]() "Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
![]() Last edited by fekete on 7th Dec 2015 7:49pm. Edited 3 times in total |
![]() Last edited by fekete on 7th Dec 2015 7:48pm. Edited 1 time in total |
Karlos, I'd fill it up with coolant, preferrably bright blue as if you do have a leak it'll be easier to spot!
![]() Treat every day as if it is your last....one day you will be right!! |
![]() Last edited by fekete on 7th Dec 2015 7:50pm. Edited 1 time in total |
