Home > Technical > 90 losing power
Page 2 of 2 <12
K9F
If you've had it serviced the level and concentration of it should hopefully have been checked. As we are heading into warmer weather and it's just a pint water will be fine in my opinion!
Pink/blue it doesn't make any real difference in my book, but blue is easier to spot in the event of a leak/seap from pipework.
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #226173 10th Apr 2013 10:28pm
fekete
Mr. Green NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #226181 10th Apr 2013 10:47pm
leeds
Sounds like the engine management system has been working fine.
Bet you did not see any noticeable rise in temperature on the chocolate fire guard of a L R temp gauge?
What age/ mileage on vehicle?
Top up with water will be fine as long as coolant concentration level is correct before next cold spell!
Advice used to be do not mix coolants as there might be a reaction between the different coolants. How true or not that is I do not know.
Fingers crossed it is a loose hose clip/ split hose but be prepared to Big Cry Big Cry Big Cry If it is more serious.
We got LR to contribute BUT it still hurt.
Brendan
Post #226223 11th Apr 2013 8:16am
fekete
Post #226274 11th Apr 2013 1:07pm
td5 commercial
2014 Defender 90 Puma 2.2 HT Baltic Blue
fekete wrote:
Thanks mate, going to have a good look this afternoon Thumbs Up
Fekete, don't fall into the trap of assuming its the head gasket, I have had one where the egr cooler split and leaked internally, had exactly your symptoms, remove egr cooler from rear of the head and pressure test it, very easy to do, and the part was quite cheap.
hope this helps (even though last time I posted on here your were being a proper nob!)
Post #226296 11th Apr 2013 2:03pm
fekete
Post #226385 11th Apr 2013 6:23pm
fekete
Post #226392 11th Apr 2013 6:34pm
fekete
Post #226394 11th Apr 2013 6:38pm
Page 2 of 2 <12
