Home > Technical > 90 losing power
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
90 losing power
Mr. Green NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #226062 10th Apr 2013 4:28pm
Green Machine
http://www.defender2.net/forum/topic17174.html?highlight=speedo
Does this help? 2005 Td5 | 90 Station Wagon | Tonga Green
Post #226064 10th Apr 2013 4:35pm
fekete
Post #226065 10th Apr 2013 4:38pm
Green Machine
No worries - hopefully that's all it is. Thumbs Up 2005 Td5 | 90 Station Wagon | Tonga Green
Post #226066 10th Apr 2013 4:40pm
EGR stuck open could cause a lack of power too. Although likely to put up the MIL or log a DTC though which I assume you've not had. _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #226068 10th Apr 2013 4:42pm
fekete
Post #226070 10th Apr 2013 4:55pm
leeds
Small loss of coolant can cause EMS to kick into limp home mode. Temp drops and then full power again.
Brendan
Post #226085 10th Apr 2013 6:08pm
fekete
Post #226097 10th Apr 2013 6:44pm
leeds
IF, and I repeat if you have a small loss of coolant do not be fobbed off with main dealer saying it is a weak pressure cap.
Yes they will replace pressure cap foc, however you may have a more serious problem such as a head gasket job.
IF you just loss power under load, I.e. hills/towing briefly for less then 30 seconds and NO apparent temperature rise with a small loss of coolant I would strong suspect head gasket.
Yes I have that tshirt!
Brendan
Post #226109 10th Apr 2013 7:36pm
GUM97
Didn't look like you were losing power when you were up my backside coming onto the estate yesterday morning Whistle Laughing
Hope you sort it out mate Thumbs Up An engine to TDi for!
Post #226119 10th Apr 2013 8:10pm
fekete
Post #226130 10th Apr 2013 8:35pm
fekete
Post #226131 10th Apr 2013 8:36pm
fekete
Post #226146 10th Apr 2013 9:13pm
K9F
Karlos, I'd fill it up with coolant, preferrably bright blue as if you do have a leak it'll be easier to spot!
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #226159 10th Apr 2013 9:41pm
fekete
Post #226164 10th Apr 2013 10:02pm
