Home > In Car Electronics > The definitive Defender ICE thread
Page 32 of 71 <123 ... 313233 ... 697071>
Nice one Jim. Are those 8" SUBS OR 10"s? I would have considered doing something similar myself but it's just impossible as I need to use every bit of the rear. Can you feel the bass now over the engine? Laughing ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #225613 8th Apr 2013 10:31pm
Killer90
Site Sponsor
Thumbs Up `Nice Steve, i need to get something sorted for mine, im forever pulling over Whistle Laughing CSK Automotive
www.cskautomotive.co.uk
Post #225615 8th Apr 2013 10:34pm
Do you still have that Parrot thing? Whistle ____\We|Will|Win/___
Post #225626 8th Apr 2013 11:09pm
barbel jim
10 " subs. They are in sealed enclosures. Wanted the smallest I could which was the decider in the choice of sub. Would have had a pair of focals to match everything else but they are designed for ported enclosures, and are deeper. Prefer sealed subs as more punchy, and you don't get that bluring/farty bass. Oh yes you can feel the bass a mile down the road,that mono amp would happilly run another pair if I wanted !!! Those amps are overkill and a total extravergance but the SQ is unbelievable ! Bow down
Dynamat stops me looking too much of a Chav though, it contains so much sound inside Thumbs Up
Designed the box to be easy in and out. Made 2 brackets that riveted to bulkhead, then a couple of self tappers hold it in situ. 2 wire's out the amp and out it pops! Thumbs Up Mine has to work for a living too.
Post #225642 9th Apr 2013 12:11am
Do you have one of those Vibe quick release connector type things then? Or something you made yourself? Thumbs Up ____\We|Will|Win/___
Post #225751 9th Apr 2013 11:13am
barbel jim
No Quick release. The amps use good old fashioned gold Allen bolts. Soldered up the wires going into connector, Simples Whistle Whistle . You can get those connectors to fit in the sub box, but I don't like them. 3/4" MDF holds the sound , then you put in a piece of 2mm plastic. I just hard wired my box and sealed the wires in . Thumbs Up
Post #225780 9th Apr 2013 1:38pm
I get what you've done. Thumbs Up I know the general thinking of heavy bass is for Chavs but using proper kit and in the correct way you cannot beat it. After all they could never afford anything other than Halfrauds el cheapo stuff. Premium all the way for me.
Mr. Green
They often never even set it up right and just sounds like air movement. Oh and then their car catces fire though improper wiring. Rolling with laughter ____\We|Will|Win/___
Post #225799 9th Apr 2013 4:13pm
barbel jim
Mr. Green
Ultimately Steve its all down to personal taste. We all have a different ear and you have to build a system to suit you. Sometimes premium is not always better, but invariably it is. Setting it up correctly is the secret.
The dynamat is one of the most important upgrades with our vehicles. Not just to keep noise out, but in reality it improves the acoustics beyond recognition.
I find you have to play around a bit too. I should have gone with my instinct in the first place and just brought the Focals. Would have saved alot of time. Rolling Eyes Having said that by doing it in stages you appreciate what you have , and need to improve. I tried a few ideas to avoid the sub box, but you can only get that rounded sound from moving air, which the little active boxes can't. I think its because its obvious in your face and not hidden that bothers me. If It wasn't a workhorse, I would have trimmed the box in carpet, and covered over the subs, giving a stealth look, But that won't last long throwing kit into the back Whistle
Post #225812 9th Apr 2013 4:57pm
Very true. My issue is that I use the rear for hay bales practically very week so pulling subs out that often would be a chore and no doubt may cause damage anyway and in the time in-between the dogs are in there and need the rooms so again not going to work. I am quite happy with my single sub though but I also agree that Dynamatting is a good idea I need to do that in time. As you say a step at a time you can really concentrate then and get things right and perfected first time. Then when finally completed you can step back and enjoy. Cool ____\We|Will|Win/___
Post #225815 9th Apr 2013 5:04pm
barbel jim
Be nice if you get it perfect first time. I thought that would happen with the 6x9's but it just started me off !!! Banging Head Banging Head Banging Head I have enjoyed it though, bored the wife and ended up with a really sweet sounding 90 Very Happy Truth is until you get it all in, wired and working, your not too sure how it will sound Confused With me its all about clarity, and I have that in spades, with far too much available volume. Thumbs Up
Oh and yeah I not too sure if the dog appreciates the subs..... But they are supposed to be like their owners, so she's a proper bass head. Big Fish, Little Fish, Aluminium Box Rolling with laughter
Post #225820 9th Apr 2013 5:17pm
barbel jim wrote:
With far too much available volume.
Same with me I usually use around the 12 mark all the time. And that is in a 0 - 35 range. Shocked I find around that is about right for normal use without going deaf and also having a convocation at the same time. If I'm on my own perhaps 13 or 14. 16 and up is nuts. Shocked ____\We|Will|Win/___
Post #225835 9th Apr 2013 5:37pm
taffrican
Wales 2002 Defender 90 Td5 HT Java Black
Steve, I could use some advise please on an amp/sub/speakers install, this is my first time ever when it comes down to amps and ICE so be gentle with me Whistle
I recently acquired an amp from "Landlord" (another member here) it is a Kenwood KAC 849, so for that I blindly went in search for a subwoofer Whistle and ended up with one of these (for next to nothing) http://www.sonicelectronix.com/item_8335_P...html#tabs.
I then ordered a pair of these for the front speakers : Kenwood kfc-e1064, after seeing you recommended them to another chap here Thumbs Up
I already have, a pair of kenwood kfc-6979ie 6x9 3 way speakers which are also new old stock.
All of this will be coming off my headunit which is one of these http://www.kenwood-electronics.co.uk/produ...-DAB4551U/
I have trawled the web looking for hints, tips and advise on whether this kit will match and seeing as some of the stuff is discontinued I am struggling to find answers. The sub is brand new old stock, the radio is fairly new as its been in my 90 for the past year, front speakers obviously brand new, the 6x9's are in perfect condition and the amp looks good (tho' not tested)
What I would like to know from an expert Bow down like yourself is, should I have the fire brigade on standby?, am I gonna blow this amp or sub? I know the amp should be 50% bigger than the sub but have I gone too big? is this just one big disaster just waiting to happen?
Thanks for any advise you can offer and sorry for all the links, but they will give you better info than I could.
Mike Bow down Optimists say the glass is half full..
Pessimists say the glass is half empty..
Engineers say the glass is twice the size it needs to be!
Post #225980 10th Apr 2013 3:38am
Hi Mike,
Sorry for the later reply I somehow missed your post. Confused RMS power of the Amp should match the Sub give or take a 5% rough estimate of leeway IMO for example... My Sub is 450w RMS and Amp is 500w RMS this is fine so long as I don't turn up the Amp to high volumes permanently. (Not likely)
RMS Wattage = Constant power input or output.
Peak = The peak wattage either the Amp output or the Sub input.
The jist is the Amp & Sub power ratings needs to more or less match if it's a single mono Amp.
Also the correct prescribed fuse rating for the Primary power feed is also critical for safety's sake.
It's difficult for me to advise without having the actual details in-front of me what is suitable.
I notice you are not too far from myself a neighbouring county in fact so if you like I could take a look or perhaps give you a hand if you wanted?
Feel free to drop me a "PM" if you'd like any further help / advice.
Steve
Post #226182 10th Apr 2013 10:48pm
taffrican
Hi Steve, thanks for your reply, I just re-read my post and the one thing I forgot to include was any spec. on the amp, here is a pdf, http://manual.kenwood.com/files/B64-1969-00.pdf which will give all the req info.
Many thanks for your offer of assistance, I really appreciate it, the last thing I would want to do is impose on your time other than forum time Laughing
I am planning on installing everything in the next couple of days and it will be done in stages as I have to build the sub into a box I already have in the back.
Mike Thumbs Up Optimists say the glass is half full..
Post #226199 11th Apr 2013 12:28am
Okay, Had a look at the details and the Sub is actually higher power rated than the Amp which isn't too much of a problem although you my find you need to adjust the settings on the Amp a little to compensate. Also I assume you were intending to use the Amp solely to power the Sub? As ideally the 6x9's should be Amped too but you would need another lower rated Amp to do this as running Kenwood 6x9's is a bit much for a HU as it only has 4x 50w outputs as a rule and will make it run very hot.
Also where were you thinking of fitting your speakers and kit in relation to the Defender?
Post #226244 11th Apr 2013 10:47am
