Home > Technical > Help-no constant power (electrical)
Cracka
2012 Defender 90 Puma 2.2 HT Fuji White
G'day Guys,
I was fitting my heat unit and checking the output power connections from the grey ISO plug (with multimeter) this morning and unfortunately shorted across the negative and the constant power coming from the ISO plug. I didn't think anything at the time and drove away and then realised when I got back in my speedo tripmeter had reset and I had no interior lights.
Long story short got home and I have checked all of the fuses and can't find a blown 1 anywhere. I have no interior lights, tripmeter resets when vehicle turned off, no clock power. I haven't got the little red flashing alarm light on the dash either, locked or unlocked.
Central locking works and also sounds the horn still if doors open.
Edit: Just realised the tacho sits at about 700 when swithced off and also the EGR isn't doing its cleaning cycle all was good prior to this. Big Cry what have I done.
Edit: I just moved the car in the driveway and the anti stall is also not working, this looks like it has affected the ECU somehow somehow, surely not, god I hope not.......
Any suggestions.
Mick
Post #224472 4th Apr 2013 1:45am
Cracka
Well, call me stupid, call me a d---head call me everything.......don't worry I have. I reckon its worse when you stuff something up yourself than if someone else does it, I'm flailing myself now, oooooh hang on.....
You know how I said I checked every bloody fuse, fusible link, relays the lot I was stumped. So I packed the whole lot up, tools away, dash back together thinking it would be a trip to the dealer 3 hours away, totally p---ed off.
Went for a 10km run to cool off, came home thought to myself, get a ground and check all of the fuse holders to make sure they are getting power. Started under the drivers seat, and checked the fuses and links once again, all good. Move on to the secondary fuses, get to fuse FL29 (Diagnostic socket,clock,entertainment system) pull the 10 amp fuse, hold it in front of the work light and what do ya know the f----n thing is blown Embarassed Rolling Eyes Evil or Very Mad how did I miss this before, 49 yr old eyes I reckon.
Well replace it with a spare and all is well, everything is working.
How the bloody hell can that fuse affect the EGR, Anti Stall, Trip meter.
Well Im a happy camper now I'll be able to go back and put the head unit in tomorrow.
I'm going to get dinner and a cider now Thumbs Up
Mick
Post #224493 4th Apr 2013 8:55am
dgardel
Italy
Thumbs Up Thumbs Up Thumbs Up Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #224521 4th Apr 2013 10:27am
I think you'll find that this fuse also powers most if not all of the Ipac (instrument panel ECU).
Post #224537 4th Apr 2013 11:02am
Cracka
Aha........
I tried to figure the electrical diagram from the manuals downloaded from DG Thumbs Up and tried to follow that, but that confused me as well.
I shall no in future though.
I'm going to buy extra spare fuses and also long nose pliers to leave in the car, that white plastic tool to remove the blade fuses is hopeless. Long nose worked well though Thumbs Up
Mick
Post #224546 4th Apr 2013 11:22am
spudfan
Ireland
Thumbs Up
How much would the dealer have charged you to sort that out? Well worth the 10km run!
Reminds me of the time when a side door on the 110 station wagon would not open from the inside. I had the tool box out ready to try and sort it out, when my daughter, who has Down Syndrome, pointed out to me that the child lock catch had inadvertedly been engaged.
Often thought of getting her a job at a maindealers. Rolling with laughter 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #224550 4th Apr 2013 11:41am
Cracka
Rolling with laughter not wrong Spud. Enough to calm down and regroup.....
Spud, that's priceless mate, my wife and I just had a laugh about you and the lock. Your daughter is a gem, luckily she was on the ball.
That kiddie lock is a pain, I flicked mine on, on the rear door in the 90 and hopped in the back and closed it, just to see if it worked, duh, as you do Rolling Eyes the wife was at work so I had to climb over the front seats....what was I thinking.....
Post #224551 4th Apr 2013 11:44am
spudfan
Ireland
Yep, keeps me smiling too.Check this out. Here she is on the series 111.
http://www.defender2.net/forum/topic14436.html 1982 88" 2.25 diesel
Post #224566 4th Apr 2013 1:03pm
Cracka
Thats a great photo of both your beauties mate.
Post #224686 4th Apr 2013 9:18pm
spudfan
Ireland
Thumbs Up 1982 88" 2.25 diesel
Post #224706 4th Apr 2013 9:40pm
