![]() | Home > Technical > Battery terminal corrosion |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2967 ![]() ![]() |
Google it thers a wealth of information
Caused by electrolosis between different metals.
Coat with Vaseline to stop it happening. ![]() |
Luismi Member Since: 04 Nov 2010 Location: Cotswolds Posts: 178 ![]() ![]() ![]() |
That is caused by a galvanic reaction when you joint to diferent metals.
By putting the dielectric grease all around reduces the galvanic reaction. Cheers |
Petroleum Jelly (Vaseline) also stops the corrosion
![]() "Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6041 ![]() ![]() ![]() |
Cheers peeps. For now the terminals have been coated in wurth battery grease and then a smear of grease over the top of the terminal. Fingers crossed. 1999 Defender TD5 110
