Home > Technical > Battery terminal corrosion
excossack
Today I noticed on the + terminal that there was some white crusty corrosion, so did the decent thing and took the terminal off and cleaned it up with a wire brush on a drill and did the same with the terminal.
Re-assembled and covered the terminal in Wurth battery grease.
What causes this? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #219034 14th Mar 2013 6:20pm
ibexman
Google it thers a wealth of information Whistle
Post #219039 14th Mar 2013 6:43pm
Laurie
Caused by electrolosis between different metals.
Coat with Vaseline to stop it happening.
Post #219042 14th Mar 2013 7:03pm
Luismi
Spain 2004 Defender 110 Td5 SW Alpine White
That is caused by a galvanic reaction when you joint to diferent metals.
By putting the dielectric grease all around reduces the galvanic reaction.
Post #219044 14th Mar 2013 7:07pm
GUM97
Petroleum Jelly (Vaseline) also stops the corrosion Mr. Green An engine to TDi for!
Post #219054 14th Mar 2013 7:31pm
excossack
Cheers peeps. For now the terminals have been coated in wurth battery grease and then a smear of grease over the top of the terminal. Fingers crossed. 1999 Defender TD5 110
Regards
John M0VAZ
Post #219290 15th Mar 2013 5:11pm
