![]() | Home > In Car Electronics > The definitive Defender ICE thread |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21005 ![]() ![]() |
Well done that man. ![]() ![]() ![]() ![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1457 ![]() ![]() ![]() |
Maybe
![]() ![]() Just so she didn't feel lost, I cranked the stereo up ![]() ![]() ![]() |
It's only because it cuts down on the talking time.. So when you've had enough you can just turn on and crank up the sound system.
Think you mean listening Time
Not so sure about that if you have a powerful enough Sub put in her hair would be the talking point instead.
Doesn't around 32/33 hertz do a lot more than mess with hair
Yes it does.
This arrived today:
![]() Click image to enlarge ![]() Click image to enlarge Only bought really because the price was so reasonable. Currently raw Alu at the moment but with a coat of paint should look pretty good. Not sure if I'm going to use it though because I like my current one a lot. Might just keep for decoration. ![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
Been pricing stuff up
Kenwood ![]() ![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
Just want a simple looking (old skool) head unit like wot I got. Things start to get complicated when you run multiple amps, and you need to be able to change the settings as you change the artist recordings. Its a bit of a faph when you start altering the gains etc. Have you seen the new Rockford fosgate amp- 300 RMS 4 channel, about the size of 3 fag packets ???
Can't say I have but I know what you mean about the settings. A lot of different makes are going for small compact amps now. Just as good with the same output and often class D. Prices is the only thing though often a bit more but for the class D efficiency I think it's worth it. The Kenwood KAC - 1XD I think it's called is worth a look. ____\We|Will|Win/___
I also need to upgrade my tweeters which I'll be doing soon too. ____\We|Will|Win/___
Kicker tweeters are still in the pipeline and it's only a matter of time now. Certainly not cheap that's for sure at £90 a pair.
