![]() | Home > Technical > Gear crunches going from 2nd to 3rd when cold |
Captain Speaking Member Since: 23 Jan 2012 Location: Oxfordshire Posts: 159 ![]() ![]() |
Me too! I just accept it as part of the fun
Shax Member Since: 05 Oct 2010 Location: London Posts: 391 ![]() ![]() ![]() |
Mine has been doing it for 2 1/2 years... The stealers all say "They do it, live with it..."... Gotta love the MT82!! ... ,-------,
.. I [__][_]|__ .. I __ |"_|"__| .. "(o)====(o)" ^^_-^-_^-^_^^^^^--^^^^ PAUL G7ALW 14.200 USB 26FB458 / 27.275 SSB |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17849 ![]() ![]() ![]() |
Double-declutch.
Tp81 Member Since: 17 Oct 2012 Location: Glasgow Posts: 35 ![]() ![]() |
Love it.
I will try the double-declutch tomorrow. It's almost like a quick wake up kick and then it performs beautifully. |
couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1830 ![]() ![]() ![]() |
I looked for a solution years ago and came across Evo oil sold on the Difflock website...might be worth looking into...
http://forum.difflock.com/viewtopic.php?p=...db8e58cc00 A bit old, but the oil is still sold. Not tried it, but my gearbox is a bit rough on the 2nd/3rd change too, so need to see if I can improve things. Cheers Simon |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 ![]() ![]() ![]() |
is this problem on the Puma or the R380 gearbox. I had this problem on my 300tdi which was cured by a gearbox oil change and slowing the change a tad.
thankfully my Puma box is very smooth. BM52 |
Dobby Member Since: 23 May 2012 Location: East Seaxe Posts: 187 ![]() |
Give the gear stick a bif of a left-right waggle just as it goes into 3rd gear. If you push 'straight' into 3rd it'll crunch, but if you shimmy it in you might be ok. No idea why, but it's worked for me on several different vehicles.
XS Pete Member Since: 13 Jan 2011 Location: Suffolk Posts: 632 ![]() ![]() ![]() |
Having watched one of my Chrismas DVDs last night (Mark Evans - a 4x4 is born), which included a wander round Ashcroft Transmissions, and a good look at a couple of gearboxes which had been sectioned so that you could see what was going on inside, at least I now know exactly which bits it is which crunch!
Pete |
yorky Member Since: 25 Aug 2012 Location: West Yorkshire Posts: 119 ![]() ![]() ![]() |
he he, I remember my grandad telling me about double de clutching when he drove an AEC double decker bus in the 1960's. Dont you just love the way LR have evolved! ![]() Volvo V70 |
rossy Member Since: 29 Nov 2010 Location: Co. Roscommon Posts: 1296 ![]() ![]() ![]() |
mine was the same until I changed the gearbox oil for Castrol SMXS (now rebranded Syntrans multivehicle 75-90 - same stuff though). I also learned - through forum advice - to change gear slowly and deliberately
lukev01 Member Since: 24 Mar 2012 Location: Bedfordshire Posts: 412 ![]() ![]() ![]() |
Even modern cars will benefit from double declutching to smooth the gear changes. I'm sad enough to do it on the daily driver - it has got to last a few more years!
![]() On a Series LR, you don't even need to use the clutch if you get the revs right ![]() |
sweepc Member Since: 19 Jun 2011 Location: uk Posts: 568 ![]() ![]() |
I have only had my car for a few weeks now and I too have this, I have tried the double-declutch and it does work but I just wondered how everybody else is getting o with this problem?
tazmarkuk Member Since: 24 Jan 2012 Location: Birmingham Posts: 134 ![]() ![]() ![]() |
I had very similar issues 2 winters ago, replaced gear oil with EVO from Difflock, never had the problem since
[quote="tazmarkuk"]I had very similar issues 2 winters ago, replaced gear oil with EVO from Difflock, never had the problem since[/quote]
Mine is a 2.2 Puma, only a few weeks old so im guessing its the MT82 box? |
