![]() | Home > Technical > Gear crunches going from 2nd to 3rd when cold |
Splitpin Member Since: 07 May 2013 Location: Midlands Posts: 100 ![]() ![]() |
Slowing the gear change sorted it for me
sweepc Member Since: 19 Jun 2011 Location: uk Posts: 568 ![]() ![]() |
Thanks for the comments, the problem only occurs on the first change from 2nd to 3rd each morning it is then fine for the rest of the day so im guessing that it isnt down to anything being loose?
dorstsmith2 Member Since: 06 Aug 2012 Location: On the third rock from the sun in dorset Posts: 188 ![]() ![]() ![]() |
have you tried oil changed ?
[quote="dorstsmith2"]have you tried oil changed ?[/quote]
No not yet as the car is only a few months old, I have considered an oil change as my first thoughts were that the oil wasnt circulating properly? |
few months old from new or to you
[quote="dorstsmith2"]few months old from new or to you[/quote]
From new onlu has 600 miles on |
miss read back to LR under warranty
Tried a slow gear change this morning and it went in fine!
i must admit mine gear crunches from time to time but it not fresh out rapper
TD5 2003 80.00 miles ![]() ![]() |
