Home > In Car Electronics > The definitive Defender ICE thread
Page 24 of 72 <123 ... 232425 ... 707172>
Gonna get plenty of bang for your buck out of that. Shocked And I think your right. Active subs are okay but you need to bring in the big guns for serious power. Cool
Thumbs Up ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #205282 25th Jan 2013 6:52pm
barbel jim
The active sub was great with the previous set up, The problem comes them new speakers are loud Shocked Really impressed with them, and the quality and clarity is excellent. Made by 'Earthquake' American and a name I remember from a few years ago. Thumbs Up
They give out nearly as much base as the sub, but that isn't enough when you start to turn it up. I'll have a play and try and alter the settings a bit, but think I already know the route i'll be taking ultimately !
Post #205290 25th Jan 2013 7:09pm
Good to hear. I take it a US made brand? If so they sure as hell know how to make powerful audio kit over there.! Cool ____\We|Will|Win/___
Post #205307 25th Jan 2013 8:13pm
barbel jim
Yes they are from the USA. They were big on the scene 15 Years ago IIRC. Really pleased, the boxes are big, but don't intrude too much for my needs, and when covered will blend in alot better, and the sound more than makes up for it. Very Happy I'll post a picture once done. Thumbs Up
Post #205584 26th Jan 2013 6:45pm
Pictures would be ace. What covering are you going to use carpeting or leatherette type stuff? If you go carpet please go Jet Black. Wink ____\We|Will|Win/___
Post #205594 26th Jan 2013 6:57pm
barbel jim
Was thinking that rubber checker matting. You can see it on the tub sides. Got some aluminium angle to cover the joins, which I will spray black. Failing that it will be BLACK acoustic cloth Wink its sitting here, used it on the amp amd sub board on the bulkhead.
Just feel the rubber will be different and match the other, being more practical and feel more OEM Thumbs Up
Post #205598 26th Jan 2013 7:10pm
That looks great. How are you finding the clearance with the rear of the seat? ____\We|Will|Win/___
Post #205599 26th Jan 2013 7:14pm
barbel jim
Not too much of an issue. We are not the largest, the center seat is fixed and when we go out, the wife has to sit in the middle !! It still goes all the way back on the runners. Thumbs Up
Post #205609 26th Jan 2013 7:25pm
Good to hear. When I was fitting my bits and pieces I found the biggest issue was finding the room to fit everything. That said it is possible and in the end can be made really neat. Far better than it looking like it's just been connected up and shoved anywhere. ____\We|Will|Win/___
Post #205613 26th Jan 2013 7:33pm
barbel jim
Totally agree Very Happy It takes some effort but solutions can be found. Sometime though I think people get so excited, get it working want to play and forget that I'll do that tomorrow attitude never works In some ways we're spoilt. Those speaker boxes once covered will look chunky and tough, a bit like the vehicle- You wouldn't get away with it in a normal hatchback Laughing !!!
Post #205637 26th Jan 2013 8:06pm
No it'd be painstakingly working with fibreglass instead which I've never done but that's what I'd go with if I did and then paint. bBut a lot of work to do with that and a pain having to wear loves and masks when sanding ect. Presides rounded curved shapes don't suit a Defender. Laughing ____\We|Will|Win/___
Post #205641 26th Jan 2013 8:12pm
barbel jim
You'd also struggle on the size, and struggle to get thee density of material for the sound. Did a bit years ago, and sandwiched plastercine between layers . Good but not the same. Its also very hard to get a good finish, that dose not age, distort or crack over time.
Post #205644 26th Jan 2013 8:18pm
I don't dis-believe it. I expect also any bending or movement could create a crack too. Especially in paint when installing. ____\We|Will|Win/___
Post #205653 26th Jan 2013 8:32pm
barbel jim
covered the enclosures today. Wanted to spray the ali black, but a bit cold, and probably not that practical. Its a working landy and I think it will look nice black but worse once it has a couple of scratches and chips Sad What do you think Steve ?
Post #205935 27th Jan 2013 5:42pm
Top work! I'd leave as is personally as from a colour coding point of view as it isn't silver in a sea of black. If you do them black they would look nice but as you say will likely get scratched and then look really bad. + you'd ideally need black screws or at least I would anyway.
Thumbs Up
How's the sound then? Razz ____\We|Will|Win/___
Post #205936 27th Jan 2013 5:46pm
