foxkilla Member Since: 01 May 2009 Location: J23 M1 Posts: 156 ![]() ![]() ![]() |
@ BM52
Yes it is an Ashcroft conversion. |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 ![]() ![]() ![]() |
Nothing........ Turns out that the fuel in Cyprus is soooo cheap it waxes up at 0 degC !!
Glyn ![]() ![]() |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3666 ![]() ![]() ![]() |
took it for a drive around Tamworth, Atherstone, Hartshill, Coleshill spotted a nice SVX and some modded 110s at just under 7000 miles its running great, and the heated seats proved themselves DEFENDER 90 TDCI XS,
LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11325 ![]() ![]() |
Loaded various stuff into it in preparation for moving house on Monday
![]() 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Defender-Stu Member Since: 14 Jun 2012 Location: South West England Posts: 1320 ![]() ![]() |
Drove to work this morning and will be driving home in a little while
Nobby Member Since: 09 Aug 2012 Location: Wiltshire Posts: 444 ![]() ![]() ![]() |
Well I connected the Amp and fitted the Sub, also fitted the check temp gauge, not finished as I need help connecting into AC. (Separate thread in technical will hopefully show the way?) Check temp works fine other than that. _______________________________
Puma Defender 90 |
cinstone Member Since: 29 Nov 2010 Location: Stourbridge Posts: 375 ![]() ![]() ![]() |
Went to the Heritage Motor Centre, Gaydon;-
![]() Click image to enlarge Chris. http://shropshirelandrovers.freeforums.org 2015 Defender 90 XS SW & Helen, 1964 IIa. Previously 2012 Defender 90 XS SW & 2008 90 XS SW. Previous LR's: Michael, my 2008 Defender 90 XS SW. Machinas oportet intrare non capsicum annuum faveo |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20795 ![]() ![]() |
Not today as such but went from this:
![]() Click image to enlarge To this: ![]() Click image to enlarge Photo doesn't do it justice really but it's a nice gloss black fascia now courtesy of Chris of CSK. ![]() Cannot stand silver on things like this so I'm very happy indeed. ![]() ___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Lishlandy Member Since: 26 Oct 2011 Location: High Wycombe Posts: 941 ![]() ![]() ![]() |
Fitted my Mantec Rear Window guard. 30min job and that was me being cautious. ===================================
Steve 90 xs sw in Stonoway Grey - Sold 110 USW X-TECH |
Not today but yesterday... Finally got the drop arm off the steering box... Moral behind the story, always use the right tool, makes it much much easier. Also stripped and rebuilt the ball joint in the arm and also a spare arm as I had it and a spare ball joint lying around. A good day.
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
Replaced the wiper motor park switch as the wipers would not switch off, wipers parking as they should now.
WarPig Member Since: 05 Dec 2009 Location: Sheffield Posts: 1748 ![]() ![]() ![]() |
Bought an addition to my Ctek MSX 5.0 charger recently, a Ctek battery indicator. It flashes green when the battery is healthy & charged, amber if it needs topping up and red if needs charging. The Ctek charger can connect straight into the indicator to save having to remove it from the battery.
http://www.ctek.com/gb/en/accessories/56-836 Although this one is for fitting to my caravan battery when stored in my garage, I thought Id try it on my Defenders battery.. This model croc clips to the battery, but I might buy one with M6/M8 fittings and dash mount display for permenant fitting to the Defender battery. Here it is connected to my caravan battery.. ![]() Click image to enlarge Its easy to see at a glance if the battery is oK.. ![]() Click image to enlarge In my Defender.. ![]() Click image to enlarge and when my Ctek charger is connected straight to it.. ![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
That's a nice bit of kit, I have a c-tek permanently on my jet ski, that will be worth adding on
yobbie Member Since: 15 Nov 2010 Location: Isle of Wight Posts: 714 ![]() ![]() ![]() |
Added a rack so hopefully I'll have a bit more room inside when camping & getting long bits back from B&Q
![]() Click image to enlarge Last seen on Higgers 110 ![]() ![]() Click image to enlarge Thanks Bpman how lucky is that, the same colour as the rack ![]() Click image to enlarge Not quite 'on' yet as I've got to finish some parts to make it possible to fit without drilling the wing. ![]() Click image to enlarge Just in the final stages of fitting 4 RI D2's into a HD front bumper |
