Page 431 of 1392 <123 ... 430431432 ... 139013911392>
foxkilla
United Kingdom 2008 Defender 110 Puma 2.4 USW Auto Tonga Green
@ BM52
Yes it is an Ashcroft conversion.
Post #200989 11th Jan 2013 11:33pm
Glynparry25
Nothing........ Turns out that the fuel in Cyprus is soooo cheap it waxes up at 0 degC !!
Glyn Dog Sheep
Post #201027 12th Jan 2013 9:45am
LR90XS2011
took it for a drive around Tamworth, Atherstone, Hartshill, Coleshill spotted a nice SVX and some modded 110s at just under 7000 miles its running great, and the heated seats proved themselves DEFENDER 90 TDCI XS,
Post #201118 12th Jan 2013 5:17pm
Loaded various stuff into it in preparation for moving house on Monday Shocked More to do tomorrow when the packers arrive... Darren
Post #201119 12th Jan 2013 5:36pm
Defender-Stu
Drove to work this morning and will be driving home in a little while Thumbs Up
Post #201120 12th Jan 2013 5:41pm
Stripped out the back, including sub woofer, carpet, 6x9s.
Fitted more sound proofing, fitted drawer (also proofed and carpeted).
Refitting amp and 6x9s. I'm afraid the sub is now surplus Neutral
Post #201138 12th Jan 2013 6:29pm
Nobby
England 2010 Defender 90 Puma 2.4 CSW Santorini Black
Well I connected the Amp and fitted the Sub, also fitted the check temp gauge, not finished as I need help connecting into AC. (Separate thread in technical will hopefully show the way?) Check temp works fine other than that. _______________________________
Puma Defender 90
Post #201157 12th Jan 2013 7:01pm
cinstone
England 2015 Defender 90 Puma 2.2 XS CSW Keswick Green
Went to the Heritage Motor Centre, Gaydon;-
Chris. http://shropshirelandrovers.freeforums.org
2015 Defender 90 XS SW & Helen, 1964 IIa. Previously 2012 Defender 90 XS SW & 2008 90 XS SW.
Previous LR's: Michael, my 2008 Defender 90 XS SW.
Machinas oportet intrare non capsicum annuum faveo
Post #201296 12th Jan 2013 11:59pm
Not today as such but went from this:
To this:
Photo doesn't do it justice really but it's a nice gloss black fascia now courtesy of Chris of CSK. Mr. Green
Cannot stand silver on things like this so I'm very happy indeed. Mr. Green ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #201391 13th Jan 2013 12:40pm
Lishlandy
England 2012 Defender 110 Puma 2.2 X-Tech LE Orkney Grey
Fitted my Mantec Rear Window guard. 30min job and that was me being cautious. ===================================
Steve
90 xs sw in Stonoway Grey - Sold
110 USW X-TECH
Post #201428 13th Jan 2013 4:36pm
geobloke
Not today but yesterday... Finally got the drop arm off the steering box... Moral behind the story, always use the right tool, makes it much much easier. Also stripped and rebuilt the ball joint in the arm and also a spare arm as I had it and a spare ball joint lying around. A good day. Mr. Green
Post #201430 13th Jan 2013 4:59pm
Lorryman100
Replaced the wiper motor park switch as the wipers would not switch off, wipers parking as they should now. Very Happy
Post #201442 13th Jan 2013 5:49pm
WarPig
Bought an addition to my Ctek MSX 5.0 charger recently, a Ctek battery indicator. It flashes green when the battery is healthy & charged, amber if it needs topping up and red if needs charging. The Ctek charger can connect straight into the indicator to save having to remove it from the battery.
http://www.ctek.com/gb/en/accessories/56-836
Although this one is for fitting to my caravan battery when stored in my garage, I thought Id try it on my Defenders battery..
This model croc clips to the battery, but I might buy one with M6/M8 fittings and dash mount display for permenant fitting to the Defender battery. Here it is connected to my caravan battery..
Its easy to see at a glance if the battery is oK..
In my Defender..
and when my Ctek charger is connected straight to it..
Post #201449 13th Jan 2013 5:59pm
That's a nice bit of kit, I have a c-tek permanently on my jet ski, that will be worth adding on Thumbs Up
Post #201532 13th Jan 2013 8:48pm
yobbie
United Kingdom 1999 Defender 90 Td5 Heritage LE Bronze Green
Added a rack so hopefully I'll have a bit more room inside when camping & getting long bits back from B&Q
Last seen on Higgers 110 Thumbs Up so be patient Killer they do turn up for sale on here
Thanks Bpman how lucky is that, the same colour as the rack
Not quite 'on' yet as I've got to finish some parts to make it possible to fit without drilling the wing.
Just in the final stages of fitting 4 RI D2's into a HD front bumper
Post #201575 13th Jan 2013 9:59pm
