Home > Technical > JW Speaker install issues (Monkey with a Skrewdriver)
Lishlandy
England 2012 Defender 110 Puma 2.2 X-Tech LE Orkney Grey
Morning All.
Had another look this morning and i seem to have Censored up the Speaker light install. It doen't fit flush in the Bezel, it isn't secured when installed with freedom to rotate and worst of all the sidelight doesn't work. This has proved an utter disaster for me. I have changed bulbs etc before but with the new front end etc I seem to have royally cocked it up and don't know how to fix it.
Anyone got an install page for the SVX front end or knowledge to help?
My beam level adjuster is also not working at all when i turn the knob, just stays in place.
Can anyone help? One very stuck and woeful Lishlandy very close to Xmas.
***PLEASE NOTE THIS IS AN INSTALL ISSUE AND DOES NOT REFLECT IN ANY SHAPE OR FORM THE SPEAKER 8700 LIGHTS QUALITY OR PERFORMANCE THAT I AM INSTALLING, THIS IS PURELY USER ERROR***
(Thought it best to put that little disclaimer in as peoples interpretations of words can lead to pessimistic conclusions) ===================================
Steve
90 xs sw in Stonoway Grey - Sold
110 USW X-TECH
Post #193648 15th Dec 2012 9:12am
Steve I can assist chap but not until Monday
Fook knows what you have done
Post #193656 15th Dec 2012 9:52am
Lishlandy
cheers Ken, god knows! Iv'e had a complete mare with this one!
let me know where and when. Im working 8 to 5 but can do before or after. I know your usually about a few hours before and after that Razz ===================================
Steve
110 USW X-TECH
Post #193657 15th Dec 2012 9:58am
Killer90
Site Sponsor
if you fancy a drive up bring it up mate and ill have a tinker today if you want Thumbs Up Thumbs Up CSK Automotive
www.cskautomotive.co.uk
Post #193674 15th Dec 2012 11:38am
d j hutton
England 2011 Defender 110 Puma 2.4 USW Orkney Grey
I can email you over a svx PDF if you pm your email address (kindly supplied by bpman)
Dj 1989 200tdi 90 csw
2011 110 usw Orkney grey
Buy British 🇬🇧
Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html
Post #193681 15th Dec 2012 11:53am
Lishlandy
Cheers for the offer chris but am in London today. Ken has kindly offered and is quite a bit closer Thumbs Up ===================================
Steve
110 USW X-TECH
Post #193691 15th Dec 2012 12:56pm
Killer90
Site Sponsor
sod ya then Laughing no probs mate, make sure some photos go up once there in Mr. Green CSK Automotive
Post #193694 15th Dec 2012 1:04pm
d j hutton
Found your email address Steve, so pdf's sent - might help a bit.
DJ 1989 200tdi 90 csw
Buy British 🇬🇧
Post #193696 15th Dec 2012 1:06pm
Lorryman100
To get the headlamp to fit into the bezel, I had to take emery cloth to the outside edge of the headlamp to remove the thicker bits of the housing coating. Once this was done the headlamp eventually fitted into the bezel and even after that it was still a tight snug fit. Thumbs Up
Post #193699 15th Dec 2012 1:12pm
K9F
The bezels can be a b4st4rd to fit. An issue I was led to believe was 'going to be addressed?' As Brian stated emery cloth does the trick. As an addition and as there is no heat involved I also sealed the bezels with a smidge bead of sealant to stop any crud from creeping through. Sealant beginning with 'S' I used....
Laughing If you go through life with your head in the sand....all people will see is an ar5e!!
Post #193711 15th Dec 2012 1:39pm
mobilecentre
The Bezel is secured to the headlamp using the original clips and screws.
No need for sanding etc as you have the Chrome Passivate finish so the rings go straight on OE and aftermarket.
If you have an adjuster motor is it still connected to the bowl?
Post #193729 15th Dec 2012 3:20pm
ZeDefender
I had a job with the motors because LR had made such a balls up with the adjuster screws. The lower ones were in so tight that there was no room for the motors to pull the bottom back. I ended up taking all the screws out and starting from scratch. Good thing is the Speakers are Censored easy to adjust as the light cut off is so sharp Thumbs Up Tell someone you love them today because life is short.
Post #193736 15th Dec 2012 3:52pm
Lishlandy
Hi Tim, the adjuster motor is still attached as well as the screw. Do I not need the headlight adjuster for the speaker lights?
Ze.....I know what you mean, not even a month old and I have a solid coating of chalky corrosion on the adjuster screw.
As stated in the first post, I am sure it is 110% user/installer error and don't want it to turn into a Speaker justification thread. Smile we already have several of those Razz ===================================
Steve
110 USW X-TECH
Post #193784 15th Dec 2012 6:44pm
ZeDefender
Talking of "installer error" when I tried to fit the bezel on the first light, I had to do it again because
a) Despite taking care, I had it at the wrong "o'clock" position (come on - it isn't entirely obvious), and
b) after correcting a) I still had to refit the clips more precisely
In my defense, I was unbelievably excited at the prospect of switching them on for the first time Razz Tell someone you love them today because life is short.
Post #193791 15th Dec 2012 7:15pm
Lishlandy
Done.
A wise man has taught me that Red doesn't always mean 'Live'. ===================================
Steve
110 USW X-TECH
Post #194500 17th Dec 2012 10:48pm
