![]() | Home > Technical > JW Speaker install issues (Monkey with a Skrewdriver) |
Steve I can assist chap but not until Monday
Fook knows what you have done |
Lishlandy Member Since: 26 Oct 2011 Location: High Wycombe Posts: 941 ![]() ![]() ![]() |
cheers Ken, god knows! Iv'e had a complete mare with this one!
let me know where and when. Im working 8 to 5 but can do before or after. I know your usually about a few hours before and after that ![]() Steve 90 xs sw in Stonoway Grey - Sold 110 USW X-TECH |
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 ![]() ![]() ![]() |
if you fancy a drive up bring it up mate and ill have a tinker today if you want
![]() ![]() www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
d j hutton Member Since: 30 Jul 2009 Location: Dorset Posts: 1044 ![]() ![]() ![]() |
I can email you over a svx PDF if you pm your email address (kindly supplied by bpman)
Dj 1989 200tdi 90 csw 2011 110 usw Orkney grey Buy British 🇬🇧 Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html |
Cheers for the offer chris but am in London today. Ken has kindly offered and is quite a bit closer ![]() Steve 90 xs sw in Stonoway Grey - Sold 110 USW X-TECH |
sod ya then ![]() ![]() www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
Found your email address Steve, so pdf's sent - might help a bit.
DJ 1989 200tdi 90 csw 2011 110 usw Orkney grey Buy British 🇬🇧 Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
To get the headlamp to fit into the bezel, I had to take emery cloth to the outside edge of the headlamp to remove the thicker bits of the housing coating. Once this was done the headlamp eventually fitted into the bezel and even after that it was still a tight snug fit.
The bezels can be a b4st4rd to fit. An issue I was led to believe was 'going to be addressed?' As Brian stated emery cloth does the trick. As an addition and as there is no heat involved I also sealed the bezels with a smidge bead of sealant to stop any crud from creeping through. Sealant beginning with 'S' I used....
![]() Treat every day as if it is your last....one day you will be right!! |
mobilecentre Member Since: 05 Mar 2012 Location: Evesham Posts: 645 ![]() ![]() |
The Bezel is secured to the headlamp using the original clips and screws.
No need for sanding etc as you have the Chrome Passivate finish so the rings go straight on OE and aftermarket. If you have an adjuster motor is it still connected to the bowl? |
I had a job with the motors because LR had made such a balls up with the adjuster screws. The lower ones were in so tight that there was no room for the motors to pull the bottom back. I ended up taking all the screws out and starting from scratch. Good thing is the Speakers are
![]() ![]() But shout it at them in German because life is also terrifying and confusing... |
Hi Tim, the adjuster motor is still attached as well as the screw. Do I not need the headlight adjuster for the speaker lights?
Ze.....I know what you mean, not even a month old and I have a solid coating of chalky corrosion on the adjuster screw. As stated in the first post, I am sure it is 110% user/installer error and don't want it to turn into a Speaker justification thread. ![]() ![]() Steve 90 xs sw in Stonoway Grey - Sold 110 USW X-TECH |
Talking of "installer error" when I tried to fit the bezel on the first light, I had to do it again because
a) Despite taking care, I had it at the wrong "o'clock" position (come on - it isn't entirely obvious), and b) after correcting a) I still had to refit the clips more precisely In my defense, I was unbelievably excited at the prospect of switching them on for the first time ![]() But shout it at them in German because life is also terrifying and confusing... |
Done.
A wise man has taught me that Red doesn't always mean 'Live'. =================================== Steve 90 xs sw in Stonoway Grey - Sold 110 USW X-TECH |
