Home > In Car Electronics > The definitive Defender ICE thread
Page 18 of 71 <123 ... 171819 ... 697071>
Storming
Scotland 2007 Defender 90 Puma 2.4 HT Blenheim Silver
Sorry not made it clear. Just want it to pair no matter who's driving without any fafing around. There could b 4 different drivers throughout the week but only one at a time.
Post #191794 8th Dec 2012 2:30pm
Ah I see. That should be no issue either. Once paired the driver just has to BT search on the phone and connect that's it. In fact probably so long as the BT is active on the phone it'll work just by being in range. Thumbs Up _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #191803 8th Dec 2012 3:09pm
Couple of photo's that maybe useful to people interested in the Defender 2007 > audio wiring loom:
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #192471 10th Dec 2012 8:59pm
nidge n
Steve, thanks for all your help with these instructions. To confirm, for a Puma we dont need a harness adaptor?
Post #193174 13th Dec 2012 5:12pm
No not at all. ISO all around. It's great. Mr. Green _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #193184 13th Dec 2012 5:40pm
bvandyk
I took a somewhat different approach..
I replaced the rear windows for my CSW with "gullwing" doors. On the one side I built a kitchen, and on the other side I store my tools / recovery equipment. About a third of these boxes were used for the speaker boxes.
Standard Radio
Standard speakers
1 x amp
2 x 6x9's
2 x 10" subs
During the build:
Left side speaker holes:
Right side speaker holes:
The amp under the rear seat:
There you can see speakers fitted. And my fridge slide.
Here is my kitchen. On the left you can see the backside of the speaker box.
Post #193398 14th Dec 2012 10:16am
^^^^ I can see plenty of work went into that. Sorry for the late reply... I think you made a good choice in adding some 6x9's into the system I think their output and sound quality is often under estimated.
On a different note earlier on in the year I did recommend the Kenwood active sub (I forget the model number) However just having a browse tonight and I think this: http://www.caraudiodirect.co.uk/kic-hs8-kicker-hs8.html would give it a damned good run for it's money. Not sure what the output comparison is like. I would imagine more being Kicker.
Mr. Green
EDIT* Video here:  _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #195846 22nd Dec 2012 10:10pm
Done a bit more to mine lately to get it just right:
^^ Courtesy of CSK (Photo doesn't do it justice really)
^^ 50% Loose fill Polyfil (Polyester filling)
^^ Cubby internally sealed with small usable area at the top. (Internal volume measured & correct) [Carpet is also jet black not grey as it looks in the picture]
^^ Elastic strap securing lid. It's only purpose is to prevent the lid vibrating like hell when the Sub starts thumping. (It does it's job perfectly.
If you want to see more photo's you can find them on page 8 & 9 here: https://www.defender2.net/gallery/thumbnails.php?album=945
Not finished as such in general I do have a few other plans but not too much more now. Lows are sorted mids aren't too bad nor Highs. Just upgrade tweeters sometime to get the highs just right after that a little more in the rear by mids perhaps some powerful Amped 6x9's other than that no more will be required. Mr. Green I also will hopefully be adding BT to my HU system in the near future also. Not likely to use it much but a pain when I do and it's not there.. _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #196092 23rd Dec 2012 9:19pm
BigRuss
That looks good Steve,
Did you paint the centre piece yourself? Russell
2011MY 110 XS USW Black
Post #196096 23rd Dec 2012 9:25pm
Cheers Russ. Thumbs Up
Do you mean the centre dashboard or the sub grille? _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #196101 23rd Dec 2012 9:38pm
BigRuss
Dashboard centre Russell
Post #196106 23rd Dec 2012 9:48pm
Ah, That was Chris (Killer 90) He painted it for me. Thumbs Up As I said before the pictures doesn't do it justice really but the light has been so poor lately.
This is the finish:
The red flake effect in it isn't noticeable 98% of the time but in the sun or if you look closely you can see it. As far as I'm concerned he's done an excellent job. Thumbs Up _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #196109 23rd Dec 2012 9:52pm
BigRuss
That is fantastic Thumbs Up Russell
Post #196112 23rd Dec 2012 9:55pm
That was my first thoughts too. Thumbs Up If you don't already have one I'd recommend it. The standard centre dash isn't that bad don't get me wrong but a glossy centre draws the eye more and just makes it a little more classier IMHO. Also matches my gloss black HU now not that that makes much of a difference but still. _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #196116 23rd Dec 2012 10:04pm
Kraut
Germany 2010 Defender 110 Puma 2.4 SW Santorini Black
custom90steve, god of ICE!!!
Would you please be so kind to give me some advise: as posted here on page 10/11 I upgraded my sytem a few weeks ago, but the bass of the sytem is still quiet poor. Put some new Focal 2-way speakers PC100 to the front, leaving the original upper dash-tweeters as they came from factory
http://www.focal.com/en/car-audio-sound/sp...pc-100.php
To give the system a little more bass I want to install a subwoofer. Doesn't have to be a big boomboom, only a little more bass than now.
So here is the question: JVC-AVX77 has a separate sub-out with 5 volts, do I have to buy an active sub (what I dont't really like to do because of having to wire powerlines again), or is it possible to use a passive sub in a 20-25 cm hole in the cubby box (smilar to your installation) with only using one cable from the sub-out from the 4x50 watt headunit? The manual doesn't say what type is needed and if the internal amlifier gives high or low power to the sub-out. It is only stated that it gives 5 volts
http://jdl.jvc-europe.com/product.php?id=K...es_section
Thanks for your help and MERRY CHRISTMAS
Post #196176 24th Dec 2012 10:20am
