![]() | Home > In Car Electronics > The definitive Defender ICE thread |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20939 ![]() ![]() |
Good luck, ![]() ![]() Steve EDIT* In the mean time have a look at page 28 here: http://images.kenwood.eu/files/prod/2062/5...1U(EN).pdf There maybe a setting there that you can dim it to without having to worry about the dimming wire. ____\We|Will|Win/___ ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
jerseyman Member Since: 21 Jul 2009 Location: Jersey Posts: 279 ![]() |
Thanks Steve, I really appreciate the time an trouble that you take to help people out out. I will assume that I can fit the stuff myself so that gives c £800 on components. That HU is probably more than I need, so do you think that http://www.justkenwood.co.uk/car-audio.aspx/kiv-700-car-radio will give as good radio and MP3 quality?. If so that frees up enough budget to get the Kenwood active sub woofer. The £40 speaker look excellent value, I still have enough to spend a little more than that, or do you reckon that would be diminishing returns bearing in mind the Landie acoustics?. Thanks once again for all the help Brian |
jersey man (Brian) - That HU should be perfect yes but bear in mind it has no CD capability but probably like mine you won't use it anyway. You should be fine fitting it yourself no probs and you always have the manual / on-line or you could ask me if you have any issues. With the speakers I would suggest the £40 one's as there is no capability to fit larger speakers in the OE Defender speaker aperture due to clearance in the rear. However if you want to go further later on you may consider an amp for added bass & premium tweeters. 6x9's are also an option. IMHO power = quality at least with premium bands anyway.
Steve ![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
110SEB Member Since: 29 Jan 2009 Location: Essex, England Posts: 1444 ![]() ![]() ![]() |
So I eventually plumped with the Sony MEX-BT3000 CD Radio with Bluetooth (for which no ISO connector was required) and i'm really pleased with it. Good sound pick up and very clear sound out. I can recommend it for Bluetooth telephoning with an iPhone.
Photo to follow. |
^^^^ Good brand that too. Pictures would be great.
nidge n Member Since: 04 Feb 2012 Location: Cheshire Posts: 720 ![]() ![]() |
a question from a novice. i am looking for a unit that is easy to self fit, has bluetooth and ideally SD card. Any recommendations please? go easy with me
Just popping out right now. I'll have a look around for you later on. ![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
Thank you, i found a pioneer but no idea on performance and interface with the defender. I appreciate your help ![]() |
nidge n - Pioneer is one of the good brands but personally I would have a look here:
justkenwood.co.uk Only Kenwood on there have a look though to see what you fancy and what suits you best and let me know. ![]() ![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
some great units here and one that will suite my needs. Thank you steve for your help. One last question if i may? are they plug and play as far as taking out the old unit and replacing it with the Kenwood? |
Glad you found some you like. ![]() ![]() Steve ____\We|Will|Win/___ ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
Storming Member Since: 23 Nov 2012 Location: Highlands Posts: 28 ![]() ![]() ![]() |
Is there a unit that has Bluetooth that deals well with multiple phones. Looking to change standard radio to one with Bluetooth to prevent young un's picking up their phone
Thanks S |
Not at the same time but different drivers
Do you mean that you want to 'pair' your own phone using the BT on your phone and head unit BUT prevent other phones pairing with the HU's BT system? If so I believe that's possible for sure. At least with the higher end HU's anyway. ![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
