![]() | Home > In Car Electronics > The definitive Defender ICE thread |
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21033
Need to do a little bit of fiddling soon with my Sub / sub box set up. I always knew I'd have to make it 100% sealed. So I will have to fit inside a way of keeping my existing cubby with opening lid but also seal the sub in AND get the internal air volume correct. Going to see if I can squeeze in 0.75 Cu3 FT. for maximum bass and lowest frequency.. Also going to add 50% Polyfill to trick the Sub into thinking it's in a larger enclosure than it really is. As it is with the Sub not being designed for free air use nor being sealed turn it up any good volume and the cubby lid will start hopping.
Click image to enlarge Watch this space. ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
| Defender-Stu Member Since: 14 Jun 2012 Location: South West England Posts: 1320
Hi, May i ask how you got the ipod cable through the side to the passanger side shelf like in the picture as i cant seem to see a hole to do this? Cheers Stu |
Stu - Talking for F-G Here (hope he doesn't mind) I think you'll find that it's probably a drilled hole. Anyone that has the Nak glove box could do the same also. Only reason I personally don't keep mine in that area is because it's on display and I don't like having to keep taking it out every 5 secs.
Cheers Steve, i know what your saying re the on display, im not bothered as i also need the cable there for a future ipad nav mod and for the misses to use the ipad on long trips etc as is will charge the Apple items
Stu - I see what you mean now. Easier access for a passenger there too. If you have any trouble with your fitting of the the new HU you know who to come to / ask.
cheers mate will do, also how do i remove the center dash section as i see the 2 torx screws but cant see how the top coms off?
also will i need a lead to connect from the LR to the head unit? |
| BigRuss Member Since: 15 May 2010 Location: Norfolk Posts: 2785
remove the 2 screws, the radio, get some courage and pull! 2011MY 110 XS USW Black |
Hi Bigruss, do i need some radio keys to get the thing out as dont seem to have any from LR?
| Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6678
Once you get the dash out you can release the stereo from behind
wicked
also will i need a lead to connect from the LR to the new head unit? |
Depends on the what is on the new unit, but very likely that they are both the same.
The only bit that maybe different is the aerial connection, but there are converters readily available on Ebay or Halfords for a few pounds |
ok well the new unit it sony so should just be universal as in my old 2007 when i had a alpine its was a straight change, Cheers for the Help GB
| Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6732
Moved to new forum section
1988 90 Td5 NAS soft top
2015 D90 XS SW |
Martin - Thank-you.
Stu - Should be a straight fit mate fitting wise of the HU. You might need a single DIN fitting cage though. As I mentioned in previous post your more than welcome to pop over to mine if you like and I can show you / do it for you. ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
| All times are GMT |
