![]() | Home > Puma (Tdci) > Service bulletin Q068v2 |
| dgardel Member Since: 30 Nov 2008 Location: Veneto (Heart & Head) Posts: 3586
Same sensations for mine ... louder and more power but from 2800-3000rpm Wainting V4 version (and Pete BAS magic box
IID Pro MV License |
| totoD110 Member Since: 26 Nov 2008 Location: Manila, Philippines Posts: 86 |
Thank you sir! |
| Cannonball Member Since: 19 Jun 2009 Location: Co Laois Posts: 150
Any truth in a rumour that LR have a further patch update to Q068v2 in the pipeline?
Now LR is on ver. 4 (Q68V4) do you mean another one? I'm thinking that our ECU are running MS Windows...... P.s. Hi Cannonbal our nations flags are so similar......... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
| 110SEB Member Since: 29 Jan 2009 Location: Essex, England Posts: 1444
...and weather so different! |
P.s. Hi Cannonbal our nations flags are so similar.........[/quote]
Yeah, but our sheep are prettier than yours!! Seriously though, does anyone have access to the GTR? I had Q068v2 patch (issued in September)downloaded on Oct 2nd. Spoke to dealer today and his computer seems to indicate that the one I have is current. Confused to say the least! |
| fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626
Hi Cannonball mines been in for 2 days with the gearbox again iv just rang them up and they have put the latest patch in it it had the Q068v2 in it about 4 weeks ago, now there is a new one i think its the Q68v4 but not to sure i'll find out later and let you know how i get on
Cheers fekete. Dealer here suggested I call in next time I am in the vicinity. Apparently they need to hook up the ECU to their computer before they can confirm if there is a new patch or not.
New patch has been done today not the q068v2 the latest one, i've only drove it home 7 mile and not had it over 50 yet but in that short space i've found the engine is so much quieter and smoother to drive not as harsh as the Q068v2 NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Thanks for that fekete
| jamesbond007 Member Since: 28 Oct 2009 Location: Central Algarve - Portugal Posts: 172
I had v4 put in on Monday. Small improvement I think but anyway, who cares, the BAS upgrade is back in!
Discovery 3 after a Defender 110 Crew Cab TD4 and a 1964 SIIA 88 Regular. |
| mse Member Since: 06 Apr 2008 Location: UK Posts: 5117
its an interesting point - how much does any remap remove these updates and/or how much of the update is affected.
Also if you have a problem when the update is applied and it cures it but you go back to another aftermarket remap - arent you loosing some of the "other" benefits. Mike |
With the BAS remap, you keep two files: the original one (i.e. the one that the factory/dealer puts in) and the tuned file.
Before you go to the dealer, you put the original file back in. Later on, you put the tuned file back in. If the original file has been changed, the device does not allow you to put the tuned file back in. You have to send the new original file to BAS (Pete) for him to send you a new tuned file. Now, I do not know if Pete takes into account the improvements to the original file to reprogram the new tuned file. Boldly going nowhere Discovery 3 after a Defender 110 Crew Cab TD4 and a 1964 SIIA 88 Regular. |
Im aware of the reflash the original settings bit - it was more the LR updates an changes and the differences against the remap Mike |
| All times are GMT |
