![]() | Home > Technical > Tdci |
| dgardel Member Since: 30 Nov 2008 Location: Veneto (Heart & Head) Posts: 3586
http://www.waeco.com/en/6018.php Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License |
| landyman37 Member Since: 22 Jan 2012 Location: west midlands Posts: 156 |
Thanks I have emailed them. Phil |
Looks like that is analogue gauges to can sensors Thanks for you help Phil |
Anyone else know anything
Phil |
| wslr Member Since: 18 Jul 2010 Location: Wellington, Somerset Posts: 581
It is a standard high speed CAN linking the engine control unit to the instrument pack module.
So should the can signals be the same as the can signals that the td5 engine uses. What I am asking is would the td5 ecu connect with the tdci dash
Phil |
Off the top of my head, the only CAN on a Td5 was on Discovery2 using the ZF autobox.
| Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6727
No CAN on Td5 Defender, everything hardwired.
Only CAN on Puma Defender is HS-CAN between Engine ECU and Instrument Pack (and OBD socket) 1988 90 Td5 NAS soft top
2015 D90 XS SW |
Hi Martin if you look at the pin out diagram for the red plug on the ecu it shows there are a can pos and a can neg
Phil |
Which pinout?
2015 D90 XS SW |
I have got a list of PIN numbers on my PC it says I think it's 34 and 30 (or up that way some where are can inputs outputs) I will have to check which ones for deffo when I get in my pc later Phil |
Quite hard, TD5 have not CAN.... Se here for more interfaces http://www.ross-tech.com/vcds/interfaces.html and http://www.samtec.de/en/hauptmenu/produkte/hardware/hslight-ii/ Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
Give that man a buiscuit just looked through and yes it is a discovery 2 CAN high pin A35 and CAN low A32. Back to the drawing board. Phil |
