Home > Technical > Tdci |
http://www.waeco.com/en/6018.php Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License |
2nd Nov 2012 6:50pm |
landyman37 Member Since: 22 Jan 2012 Location: west midlands Posts: 153 |
Thanks I have emailed them. Phil |
2nd Nov 2012 7:04pm |
Looks like that is analogue gauges to can sensors Thanks for you help Phil |
2nd Nov 2012 10:54pm |
Anyone else know anything
Phil |
3rd Nov 2012 5:59pm |
wslr Member Since: 18 Jul 2010 Location: Wellington, Somerset Posts: 581 |
It is a standard high speed CAN linking the engine control unit to the instrument pack module.
4th Nov 2012 11:45am |
So should the can signals be the same as the can signals that the td5 engine uses. What I am asking is would the td5 ecu connect with the tdci dash
Phil |
4th Nov 2012 11:50am |
Off the top of my head, the only CAN on a Td5 was on Discovery2 using the ZF autobox.
4th Nov 2012 12:10pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6492 |
No CAN on Td5 Defender, everything hardwired.
Only CAN on Puma Defender is HS-CAN between Engine ECU and Instrument Pack (and OBD socket) 1988 90 Td5 NAS soft top 2015 D90 XS SW |
4th Nov 2012 12:12pm |
Hi Martin if you look at the pin out diagram for the red plug on the ecu it shows there are a can pos and a can neg
Phil |
4th Nov 2012 12:21pm |
Which pinout? 1988 90 Td5 NAS soft top
2015 D90 XS SW |
4th Nov 2012 4:41pm |
I have got a list of PIN numbers on my PC it says I think it's 34 and 30 (or up that way some where are can inputs outputs) I will have to check which ones for deffo when I get in my pc later Phil |
4th Nov 2012 5:11pm |
Quite hard, TD5 have not CAN.... Se here for more interfaces http://www.ross-tech.com/vcds/interfaces.html and http://www.samtec.de/en/hauptmenu/produkte/hardware/hslight-ii/ Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
4th Nov 2012 6:38pm |
Give that man a buiscuit just looked through and yes it is a discovery 2 CAN high pin A35 and CAN low A32. Back to the drawing board. Phil |
4th Nov 2012 9:37pm |
