![]() | Home > Puma (Tdci) > Reversing light failed |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20967 ![]() ![]() |
I too have the same issue. I find that only my current LED bulb will work but not the filament type bulbs. Only way to find the earth is to trace it by wiring diagram. ____\We|Will|Win/___
____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6027 ![]() ![]() ![]() |
As a quick test could you try adding another earth ? 1999 Defender TD5 110
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 ![]() ![]() ![]() |
i think you will find the earth is made by the reverse light switch in the gearbox. On some cars these are adjustable others are replace only. 2005 Td5 90 XS
Steve |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 ![]() ![]() ![]() |
anyone know where the reversing light switch is on the gearbox. can't find a picture/diagram anywhere. thought i would check the contacts are clean and dry before i have to pop it into the dealer.
thanks BM52 |
Have a look here: 3rd page you will find some pictures and some useful info too.
http://www.defender2.net/forum/topic3724.h...p;start=30 ____\We|Will|Win/___ ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
thanks, just read the posts. i will check connections and earths as best i can but as it is under warranty i may well throw it into the dealer if necessary.
thank you BM52 |
Your welcome. To be honest with you if you can't find out what it is easily and it's under warranty just get them (LR) to sort it. Chances are you'll get a new free switch too. When mine stopped working last year I had to go for the hand brake re-call and asked them too look at this also and they never charged me a penny and it wasn't even under warranty
![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
Well this all changed this morning... ![]() ![]() (And it wasn't a duff bulb either I tried two) ____\We|Will|Win/___ ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
working from today ...so while still light i have just popped out, removed reversing light and circuit tester says 12v.
it will not light a standard bulb but NOW the LED light works again. another WTF moment. ![]() |
Same as me then! What I did was clean the plug and socket right up with some tissue paper. And then once all clean some WD-40 but only on the plug and socket not the actual bulb holder (didn't think it would be too good an idea and it was completely dry anyway)
Might be worth giving it a go? ____\We|Will|Win/___ ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
SteveS Member Since: 05 Oct 2010 Location: Devon & Berkshire Posts: 388 ![]() ![]() ![]() |
I had a similar episode with mine - got strange high resistance readings on the meter and couldn't get the filament bulb to light......suddently after a bit of use engaging reverse the switch seemed to start working properly......I also wiggled the connections on the switch on the side of the geabox.....anyway its been working a treat ever since.
Tried replacement bulb, substituted the fog light in case here was something wierd with the housing. Open circuit voltage was 8V??? Somewhat frustrating for me as a chartered electrical engineer. Probably just poor/dirty connections in my case |
db950 Member Since: 01 Feb 2012 Location: Lincoln Posts: 570 ![]() ![]() ![]() |
If its a similar set up to the td5 wiring the switch on top of the gearbox is fed a positive supply down the bulkhead/engine loom plug and back up the same plug into the dash, then down the chassis loom plug to the reversing light.
The earth for all the lights at the back is supplied down the chassis loom from a couple of wires earthed on the gearbox housing. I would check the two plugs at the bulkhead as these carry the positive and are more likely to green over (corrode) The earth is worth a check as well of course! |
DB950 - Can you advise the location of the 2 plugs at the bulkhead? thanks BM52
Sorry all my advice is for a td5 so it's all hoping they are similar.
The plugs are located in the engine bay below the header tank on clips attached to the bulkhead. The engine loom plug is grey and the chassis loom plug is orange. Again sorry if this is untrue for a puma. The positive supply and return wires to the switch are thickish green ones. |
