Home > Td5 > Immobiliser gremlins
amondeggs
United Kingdom 1999 Defender 90 Td5 HT Woodcote Green
Hoping that someone else has had this so that I can fix quickly?
I have a 1999 td5 with standard factory alarm. No central locking on the car.
Problems started a couple of months ago when I returned to car with alarm set and car immobilised. I unset alarm and tried to start car and it would not start. Re set and unset again and all was well. Drove away from car park up a hill and engine cut out due to immobiliser. Reset alarm and fired up again.
Today came to get car out of garage would not start. I had not set alarm in the garage! Set alarm and unset a few times then engine fired up Rolling Eyes
Pulled car out and it stopped running due to immobiliser cutting in. Losing my temper and thinking there is a bad connection I thumped the top of the dash binnacle. Engine carried on running JUST and engine management light came on. Thumped it again and light went out. Confused
Did this a few more times and I could make the engine management light come on and go off at will. Engine stuttered a little each time but kept running.
Took car out for 30 mile drive and it behaved when I parked it up for 30 min. Once home I thumped dash again but now could not get the engine management light to come on Confused
I know this is a problem with the alarm but does anybody else have any experience of anything like this?
Any clue. To the source of the problem will be much appreciated.
Thumbs Up
Post #171361 27th Sep 2012 7:46pm
Glynparry25
I am confused..... Alarm but not central locking Confused So you can set the alarm without locking the doors?
Have you tried the battery connections? Have had it in a couple of cars when they are slightly lose and can wiggle and move about when driving which can break contact even if only temporarily which can cause all sorts of problems.... not too sure about the dash thing though
Glyn Dog Sheep
Post #171380 27th Sep 2012 8:34pm
mobilecentre
There are two types of alarm / immobilser one with central locking interface built in and one without.
I learnt this recently from Porny / IRB as I thought the boxes were all the same Thumbs Up
It will probably be your alarm unit screwed to the bulkhead which has got wet and corroded the pcb tracks which is quite common.
Post #171382 27th Sep 2012 8:39pm
Glynparry25
Sounds crazy to me that you can set the alarm without locking the car..... bit back to front so it shouldn't supprise me with Land Rover Rolling with laughter
Glyn Dog Sheep
Post #171386 27th Sep 2012 8:44pm
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
I am pretty sure the immobliser box (spider) lives behind the dials and is quite well known for dodgy connections hence your dash thumping temporarily curing your problem. You may be able to remove it and re-solder any loose connections. 2005 Td5 90 XS
Steve
Post #171387 27th Sep 2012 8:44pm
amondeggs
Ok thanks for the replies Thumbs Up
I will take apart this weekend to have a look at the connectors
Is there a multi connector connecting the box to the loom or is the wiring just part of the loom?
If I need to turn alarm off is it a nanocom job to isolate it?
Is there any manual way to isolate alarm?
Cheers in advance Thumbs Up
Post #171392 27th Sep 2012 9:03pm
Porny
Site Sponsor
There is no 'Spider' on a Td5....
Behind the clock panel there is a green box attached to the bulkhead - check both the green and the grey plugs are clipped in correctly.
The 10AS units are quite prone to water ingress, but there are a few other things than can also cause problems.
You can turn off part of the alarm function using Nanocom, but the basic immobiliser function will still be there...
However, I can remove the need to have the 10AS unit if needed - making your Defender 100% immo off.
Is your alarm keyfob attached right next to the ignition key on your key ring?
Is it the Yellow Engine MIL that is illuminating, or the red MIL with what looks like a bolt of lightening through it?
Ian IRB
The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers.
www.IRBdevelopments.com
www.facebook.com/irbdevelopments
www.integrated316.com
www.facebook.com/integrated316
Post #171410 27th Sep 2012 9:59pm
amondeggs
Hi ian and thanks for reply,
The fob is next to the key on the keying , is this a secret code I am missing?
The light that came on was the orange engine management light
Don't know if it helps but on the back of the fob it says " auto watch 376-300 r9006 Srd 16
Thanks for info Thumbs Up
Post #171422 27th Sep 2012 10:21pm
ARMYBOB
United Kingdom 2001 Defender 110 Td5 CSW Java Black
Glynn mine is like this, no central locking but alarmed, not so strange lol
have you tried changing the battery in the key fob?
mine wouldnt start once new battery started fine,
i could still arm teh alarm, but i had to be almost in the car to do it.
2001 td5110
Post #171426 27th Sep 2012 10:45pm
amondeggs
Right I have taken the dash apart tonight and realise now that my alarm is not factory fit but an auto watch alarm.
The original alarm is there but obviously not wired up.
I pulled out the auto watch alarm and tried to find a loose connection but could not
Put it all back in and all appears fine.
I guess that some wire must have been bent causing a bad connection Question
Anyway appears to be sorted
Thanks to all who offered their ideas. Thumbs Up
Post #171687 28th Sep 2012 9:50pm
Rovertech
South Africa 2007 Defender 110 Puma 2.4 SW Alpine White
It's so irritating when they fit aftermarket immo systems over existing factory ones.
Post #891937 16th Mar 2021 8:35pm
dorsetsmith
There is no 'Spider' on a Td5....( not so soft ware spider )
Post #892036 17th Mar 2021 9:02am
