Home > Td5 > Immobiliser gremlins |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 |
I am confused..... Alarm but not central locking So you can set the alarm without locking the doors?
Have you tried the battery connections? Have had it in a couple of cars when they are slightly lose and can wiggle and move about when driving which can break contact even if only temporarily which can cause all sorts of problems.... not too sure about the dash thing though Glyn |
27th Sep 2012 8:34pm |
mobilecentre Member Since: 05 Mar 2012 Location: Evesham Posts: 645 |
There are two types of alarm / immobilser one with central locking interface built in and one without.
I learnt this recently from Porny / IRB as I thought the boxes were all the same It will probably be your alarm unit screwed to the bulkhead which has got wet and corroded the pcb tracks which is quite common. |
27th Sep 2012 8:39pm |
Sounds crazy to me that you can set the alarm without locking the car..... bit back to front so it shouldn't supprise me with Land Rover
Glyn |
27th Sep 2012 8:44pm |
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 |
I am pretty sure the immobliser box (spider) lives behind the dials and is quite well known for dodgy connections hence your dash thumping temporarily curing your problem. You may be able to remove it and re-solder any loose connections. 2005 Td5 90 XS
Steve |
amondeggs Member Since: 06 Mar 2011 Location: Telford Posts: 452 |
Ok thanks for the replies
I will take apart this weekend to have a look at the connectors Is there a multi connector connecting the box to the loom or is the wiring just part of the loom? If I need to turn alarm off is it a nanocom job to isolate it? Is there any manual way to isolate alarm? Cheers in advance |
27th Sep 2012 9:03pm |
Porny Site Sponsor Member Since: 31 Aug 2009 Location: Sutton Coldfield - West Midlands Posts: 792 |
There is no 'Spider' on a Td5.... Behind the clock panel there is a green box attached to the bulkhead - check both the green and the grey plugs are clipped in correctly. The 10AS units are quite prone to water ingress, but there are a few other things than can also cause problems. You can turn off part of the alarm function using Nanocom, but the basic immobiliser function will still be there... However, I can remove the need to have the 10AS unit if needed - making your Defender 100% immo off. Is your alarm keyfob attached right next to the ignition key on your key ring? Is it the Yellow Engine MIL that is illuminating, or the red MIL with what looks like a bolt of lightening through it? Ian IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
27th Sep 2012 9:59pm |
Hi ian and thanks for reply,
The fob is next to the key on the keying , is this a secret code I am missing? The light that came on was the orange engine management light Don't know if it helps but on the back of the fob it says " auto watch 376-300 r9006 Srd 16 Thanks for info |
27th Sep 2012 10:21pm |
ARMYBOB Member Since: 16 May 2009 Location: north luffenham, rutland Posts: 81 |
Glynn mine is like this, no central locking but alarmed, not so strange lol
have you tried changing the battery in the key fob? mine wouldnt start once new battery started fine, i could still arm teh alarm, but i had to be almost in the car to do it. 2001 td5110 |
27th Sep 2012 10:45pm |
Right I have taken the dash apart tonight and realise now that my alarm is not factory fit but an auto watch alarm.
The original alarm is there but obviously not wired up. I pulled out the auto watch alarm and tried to find a loose connection but could not Put it all back in and all appears fine. I guess that some wire must have been bent causing a bad connection Anyway appears to be sorted Thanks to all who offered their ideas. |
28th Sep 2012 9:50pm |
Rovertech Member Since: 30 Jun 2020 Location: Western Cape Posts: 5 |
It's so irritating when they fit aftermarket immo systems over existing factory ones.
16th Mar 2021 8:35pm |
There is no 'Spider' on a Td5....( not so soft ware spider )
17th Mar 2021 9:02am |
