Home > Maintenance & Modifications > hella fog lights |
DJ,
My understanding is as long as the extra driving lights dip as you explained and are 55/65 wattage filaments they are road legal. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
19th Sep 2012 7:03pm |
Auxilliary lights (spots) must be wired such that they only come on with main beam and go off when returning to dipped beam. With a few specific proviso's, it doesn't matter where they're mounted - roof, A bar, bumper, etc. You can have a separate switch to prevent them coming on, but not one to switch them on independantly. You can, in theory, have as many auxilliary lights as you like in this arrangement. It's fairly logical - main beam is for use when there's nobody in front of you, so it doesn't matter how bright it is. Dipped beam is for use when facing or following another car and so is specifically controlled. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
19th Sep 2012 8:11pm |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4784 |
in which case, as my friends 100w driving lights only came on with the main beam then yes, they are legal. it was never an issue come MOT time (about the only thing that wasnt!) 2002 90 Td5 Station Wagon
20th Sep 2012 10:32am |
yobbie, pm sent 2002 90 Td5 Station Wagon
20th Sep 2012 10:54pm |
yobbie Member Since: 15 Nov 2010 Location: Isle of Wight Posts: 711 |
Don't have any pm Grafty??
21st Sep 2012 8:37am |
PM re sent 2002 90 Td5 Station Wagon
22nd Sep 2012 12:27am |
You should have a reply
22nd Sep 2012 10:57am |
I do, replied back too 2002 90 Td5 Station Wagon
23rd Sep 2012 2:01am |
MartinK Member Since: 02 Mar 2011 Location: Silverdale (Lancashire/Cumbria Border) Posts: 2664 |
Whilst driving my Defender in nasty conditions this morning, there was the usual bunch of muppets with front fogs AND dip beam at the same time (which as we know is incorrect)...
Then I had a thought....my rear fog only comes on when main/dip beam is selected (NOT on sidelights). As you;re supposed to use front fogs with sidelights (to reduce reflected glare)...do you need to somehow change the vehicle wiring so that the rear and front fogs can be used with sidelights (and not dip beam)????? Anyone done this??? Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) Last edited by MartinK on 24th Sep 2012 5:24pm. Edited 1 time in total |
24th Sep 2012 1:54pm |
On my parents Range Rover, the front fogs will come on with side lights and so will the rears but the front fogs have to be on first before the rears will come on. i.e you cant drive on sidelights and rear fogs only. 2002 90 Td5 Station Wagon
24th Sep 2012 3:15pm |
mobilecentre Member Since: 05 Mar 2012 Location: Evesham Posts: 645 |
For use on the highway the aux lights would also need to be ECE approved which is a drive type pattern so no spots I am afraid
26th Sep 2012 8:11pm |
