Home > Maintenance & Modifications > hella fog lights
Page 3 of 5 <12345>
mobilecentre
Is this the wrong time to mention we do an LED foglight designed and certified as an actual fog light?
Do not get me started on rear fog lights as if you switch them on you should not still be able to do 70mph on the motorway Mad
Post #168811 16th Sep 2012 10:42pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
@mk1collector,
No problem with the vehicle. Excellent choice for the country lanes and roads that are never gritted or cleared by the council. Just the addition of auxiliary driving lights which are never used. Obviously for looks as the roof bar lights are illegal on public roads. Would be much better if they fitted a proper lighting system that would do the job required. Most cars are fitted with more than adequate lighting systems to cope with the roads and driving conditions in this country. I could be wrong but I thing most Land Rovers, Defenders excepted, made in the last few years already have front fog lights and many have Xenon or HID lighting systems more than adequate for this country, and if you cannot see clearly then you slow down. Cross country or the outback different set of circumstances. That's my 6ps worth. Sorry if I've offended anyone.
Mind you I did enjoy last winter towing a D3 out of a snow drift. It had lots of lights on it but the driver, well the least said the better. LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #168817 16th Sep 2012 11:06pm
grafty99
I don't want two massive spot lights on the front, firstly because my main beam is perfectly adequate as it is, secondly main beam is useless in fog and also, it would undo the effect of the bigger intercooler i have fitted by blocking most of the airflow through it.
i really just wanted to know who made the bumper with the fogs in, however i do have a set of Tim's headlights so a matching set of LED fogs wouldn't go a miss! 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #168821 16th Sep 2012 11:47pm
LR90XS2011
Bet you never thought this thread would become so "interesting" and go to 3 pages
good luck and all the best Rob DEFENDER 90 TDCI XS,
Post #168826 17th Sep 2012 6:07am
Roof lights are only illegal when wired to be independently switched. If wired so that they can only come on with main beam then they are perfectly within the rules. Darren
Post #168828 17th Sep 2012 6:44am
grafty99
Yes Rob, you've hit the nail on the head, and very diplomaticly put! And I still haven't found out who makes the bumpers I posted pictures of! 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #168836 17th Sep 2012 8:12am
leeds
It is perfectly legal to have roof mounted lights on your vehicle.
They only become illegal IF they are used on the public highway, IF they are switched independent of mainbeam and are not E marked.
We suggest that roof lights are wired independent off the main switch, so that when your main light switch burns out at least you have some illumination!
Brendan
Post #168842 17th Sep 2012 8:54am
ZeDefender
It's a pity you can't "test before you buy" (unless you can get hold of a fog machine...)
I had fog lamps on my T4 VW bus and on my current Audi (I paid extra) and whenever I used them in fog or snow they just make things worse (everything just glares).
Reading this, I'm beginning to think coloured filters are essential - am I learning something? Tell someone you love them today because life is short.
Post #168877 17th Sep 2012 2:17pm
MartinK
Did you turn off your normal headlights? Fogs are supposed to be set low to see "under" the fog/snow...the normal headlights are set higher, so they reflect back straight into your eyes,
Switch normal dip beam off when using foggers - otherwise the benefit is lost... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #168883 17th Sep 2012 3:08pm
mobilecentre
Thumbs Up Exactly that use with side lights
Post #168885 17th Sep 2012 3:26pm
mobilecentre
Filters do just that filter out most of the light leaving just the desired colour left within the spectrum, wasting most of the light created as your filter blocks it.
Are you sure you are using fogs with just side lights as they should not create serious glare due to the height below the bonnet line
Post #168886 17th Sep 2012 3:31pm
ZeDefender
Embarassed Never thought to try them without headlights Thud
Cheers Thumbs Up Tell someone you love them today because life is short.
Post #168890 17th Sep 2012 3:53pm
mobilecentre
That's part of what forums are about - a place to discuss ideas and exchange information Thumbs Up
Post #168893 17th Sep 2012 4:08pm
grafty99
On the exchanging information part, who makes the bumpers with the hella fog lights in? 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #168946 17th Sep 2012 7:38pm
mobilecentre
I have PM'd the guy with the bumper and asked him where it came from for you Thumbs Up
Post #168952 17th Sep 2012 7:52pm
Page 3 of 5 <12345>
