![]() | Home > Maintenance & Modifications > hella fog lights |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802 ![]() ![]() ![]() |
Thanks Tim, I have no idea why I didn't think of that?! 2002 90 Td5 Station Wagon
mobilecentre Member Since: 05 Mar 2012 Location: Evesham Posts: 645 ![]() ![]() |
Not to mention promote products and services at every available opportunity. Steve. Owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
That's part of what being a site sponsor is about ![]() |
yobbie Member Since: 15 Nov 2010 Location: Isle of Wight Posts: 714 ![]() ![]() ![]() |
The bumper is just a standard one with holes cut in to fit the surrounds that I machined at work. I have some spare black delrin (plastic) if you want them I can send you or I can machine some more aluminum ones that I've now painted and used. ![]() |
Look remarkably like these..... http://www.firstfour.co.uk/item/2036169/de...per--grey- If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Boode pm sent 2002 90 Td5 Station Wagon
I think the first four ones look a bit bling with the chrome looking surrounds. Not cheap either! 2002 90 Td5 Station Wagon
d j hutton Member Since: 30 Jul 2009 Location: Dorset Posts: 1044 ![]() ![]() ![]() |
Bling does seem very popular, but they also list them available in black, look quite nice I thought. dj 1989 200tdi 90 csw 2011 110 usw Orkney grey Buy British 🇬🇧 Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html Last edited by d j hutton on 19th Sep 2012 11:17am. Edited 1 time in total |
I've been thinking about additional front driving lights, if I understand it correctly you can use them on a public road as long as they go off when high beam is changed to standard low beam. If that's the case having been driving along with high beam and additional lights on and another car comes towards you, you dip your lights and the high beam and additional lights are changed to dip only, doesn't that mean (having got used to the brightness of your dip/driving light combo) that you are plunged into darkness as your eyes adjust to the dip only lights? This is the only reason that I'm holding back from add on lighting at the front. Can you get road legal dipping driving lights? as that would solve the issue. I appreciate the fact that they 'look' better and would be very useful off road at night, but concerned about the 'darkness' when going to dip. Additional front fog lights I can see the benefit of (unless its broad daylight, thats when I see their used the most ![]() dj 1989 200tdi 90 csw 2011 110 usw Orkney grey Buy British 🇬🇧 Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html |
Not lightweight either 5mm thick with built in recovery eyes. Built like a girder and you get what you pay for, especially if you're going off road. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
My friends Tdi 90 has two massive wipac spotlights on with 100w bulbs in. The transition between main and dip isn't too bad. Plus it isn't for very long, when the car is passed you are back on main again. 2002 90 Td5 Station Wagon
Are 100w spotlights, however they are wired, legal on Public Roads.
![]() ![]() Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20967 ![]() ![]() |
Yes and No. Yes to the lights on an A bar or the roof however the way in which they are switched is a legal side. I believe front mounted spots may be wired using the main beam as a switch or a switch or a combo of both. However roof mounted spots I understand have to be switched only and NOT switched on or of by using main beam on the stalk.
**Correct any detail if anyone thinks it is wrong. As I mention this is my understanding ![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
